Ana içeriğe geç
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Meta Quest Pro cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Meta Quest Pro Chip ID, Headset Mainboard Side A: adım 1, 1 resimden 1.
  2. Meta Quest Pro Chip ID: adım 2, 1 resimden 1.
    • Infineon CYPD3177 USB Type-C Port Controller
    • Qualcomm SMB1355 Li-Ion Battery Charger w/ Quick Charge 2.0/3.0/5.0
    • Qualcomm PM3003A Power Management
    • Texas Instruments TLC59401 16-Ch. LED Driver
    • Texas Instruments TS3USB221 USB 2.0 SPDT Analog Switch
    • Awinic AW37504CSR ? Dual Output Power Supply
    • Analog Devices MAX77827B 1.6 A Buck Boost Converter
  3. Meta Quest Pro Chip ID: adım 3, 1 resimden 1.
    • Texas Instruments TPS62148 2.0 A step-down converter
    • Texas Instruments TPS61378-Q1 4.8 A synchronous boost converter
    • SG Micro SGM66056 2.2 MHz synchronous boost converter
    • OmniVision WS4694C 28 V over-voltage & over-current protection load switch
    • SG Micro SGM2578AAD 2 A load switch
    • Texas Instruments TLV7031 single comparator
    • Texas Instruments TLV9054 quad 5-MHz rail-to-rail operational amplifier
  4. Meta Quest Pro Chip ID: adım 4, 1 resimden 1.
  5. Meta Quest Pro Chip ID: adım 5, 1 resimden 1.
    • onsemi FSA4480UCX USB Type-C analog switch
    • SG Micro SGM4553 2-bit bidirectional voltage-level translator
    • OmniVision DPDT analog switch (possibly)
  6. Meta Quest Pro Chip ID, Headset Mainboard Side B: adım 6, 1 resimden 1.
    • Murata LBEE5xx1WK ? type 1WK Bluetooth/WiFi module
    • Nordic Semiconductor nRF52840 Bluetooth 5.3 low-energy SoC
    • Qualcomm PM8250 power management
    • Qualcomm PM8150B power management
    • Qualcomm PMK8002 ? clock generator
    • Texas Instruments TCA6418E 18-bit I/O expander
    • Renesas SLG59M1717V 5 A load switch
  7. Meta Quest Pro Chip ID: adım 7, 1 resimden 1.
    • Likely Texas Instruments LP5907UVE-1.2 250 mA / 1.2 V LDO regulator
    • DC-DC converter
  8. Meta Quest Pro Chip ID, Headset Mainboard Side B - Sensors: adım 8, 1 resimden 1.
    • Bosch Sensortec BMM150 3-axis magnetometer
  9. Meta Quest Pro Chip ID, Controller Mainboard Side A: adım 9, 2 resimden 1. Meta Quest Pro Chip ID, Controller Mainboard Side A: adım 9, 2 resimden 2.
    • Qualcomm SM6115 Snapdragon 662 Octa-Core applications/baseband processor
    • Samsung K4U8E3S4AD-MGCL 1 GB LPDDR4X SDRAM memory
    • Samsung KLM4G1FETE-B041 4 GB eMMC NAND flash memory
    • Qualcomm PMI632 power management
    • Microchip ATSAMD20G17 32-bit microcontroller
    • Renesas DA7281 haptic driver
    • Texas Instruments SN74AUC1G32 single 2-input OR gate
  10. Meta Quest Pro Chip ID: adım 10, 1 resimden 1.
    • Nexperia PUSB3FR4 4 ch. ESD protection
  11. Meta Quest Pro Chip ID, Controller Mainboard Side A - Sensors: adım 11, 1 resimden 1.
    • TDK-InvenSense ICM-42686-P 6-axis accelerometer & gyroscope
    • Allegro MicroSystems A1392 hall effect sensor
    • Allegro MicroSystems A1395 hall effect sensor
  12. Meta Quest Pro Chip ID, Controller Mainboard Side B: adım 12, 2 resimden 1. Meta Quest Pro Chip ID, Controller Mainboard Side B: adım 12, 2 resimden 2.
    • Qualcomm PM4250 power management
    • Cirrus Logic CS40L25 haptic driver
    • Nexperia 74LV1T34 single translating buffer
    • Nexperia 74LV1T04 single translating inverter
  13. Meta Quest Pro Chip ID, Controller Mainboard Side B - Radio: adım 13, 1 resimden 1.
    • Nordic Semiconductor nRF52832 Bluetooth Low-Energy 5.3 SoC
    • Skyworks SKY66111-11 Bluetooth Low Energy front-end module
    • Probably Qorvo QPC8019Q DPDT RF switch
    • Qualcomm WCN3950 WLAN 802.11a/b/g/n/ac, Bluetooth 5.0, & FM radio
  14. Meta Quest Pro Chip ID, Controller Mainboard Side B - Sensors: adım 14, 1 resimden 1.
    • Allegro MicroSystems A1391 hall effect sensor
  15. Meta Quest Pro Chip ID, Console Accelerometer Board: adım 15, 1 resimden 1.
    • TDK-InvenSense ICM-42688-P 6-axis MEMS accelerometer & gyroscope
  16. Meta Quest Pro Chip ID, Headset Mainboard Side B: adım 16, 1 resimden 1.
    • Cmedia CM7120 Audio DSP & CODEC Hub
    • Analog Devices MAX98360A Class-D Audio Amplifier
    • Qualcomm SMB1355 Battery Charger
  17. Meta Quest Pro Chip ID, Headset Block Diagram: adım 17, 1 resimden 1.
    • Predicted block diagram primarily based on available datasheets and observed implementation in product.
  18. Meta Quest Pro Chip ID, Controller Block Diagram: adım 18, 1 resimden 1.
1Rehber Yorum
Any photo-and-text-based teardown of the entire device like iFixit used to do? Love the company, but the fact that there aren't non-video articles on this under the Teardowns section is honestly a bit of a letdown. Would it be possible to bring them back? They're a really useful resource.
Ethan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 40
Son 30 gün: 211
Her zaman: 13,726
