Giriş
This guide shows how to remove and replace the entire recoil starter assembly. The assembly is an OEM part for Honda GX200 engine models.
If you replace the recoil starter with a non-OEM part, you may have to remove the starter cap. For that, you will need the following additional tools:
- 3/4” deep socket
Neye ihtiyacın var
Use a 10 mm socket to remove the three 24 mm long bolts.
Bir başkası bu kılavuzu tamamladı.
