Ana içeriğe geç
Miadore Classic N64 Controller Buttons Replacement
Neye ihtiyacın var
  1. Miadore Classic N64 Controller Buttons Replacement, Joystick: adım 1, 3 resimden 1. Miadore Classic N64 Controller Buttons Replacement, Joystick: adım 1, 3 resimden 2. Miadore Classic N64 Controller Buttons Replacement, Joystick: adım 1, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove all nine 3.2 mm screws from the back of the controller.
    • Place the end of a spudger in the seam between the top and bottom of the controller to release the clips holding them together.
    • Separate the top and bottom cover of the controller.
    FixBot'a Sor
    Yorum Ekle
  2. Miadore Classic N64 Controller Buttons Replacement: adım 2, 2 resimden 1. Miadore Classic N64 Controller Buttons Replacement: adım 2, 2 resimden 2.
    • Remove the three 3.2 mm Phillips #000 screws holding the motherboard in place.
    • The motherboard will still be in place after the screws are removed.
    FixBot'a Sor
    Yorum Ekle
  3. Miadore Classic N64 Controller Buttons Replacement: adım 3, 3 resimden 1. Miadore Classic N64 Controller Buttons Replacement: adım 3, 3 resimden 2. Miadore Classic N64 Controller Buttons Replacement: adım 3, 3 resimden 3.
    • Remove the three 3.2 mm Phillips #000 screws holding the joystick module in place.
    • Remove the joystick module.
    FixBot'a Sor
    Yorum Ekle
  4. Miadore Classic N64 Controller Buttons Replacement: adım 4, 2 resimden 1. Miadore Classic N64 Controller Buttons Replacement: adım 4, 2 resimden 2.
    • Remove the joystick by pulling it away from the plastic needle-like object holding it in place.
    • Replace it with a new or custom joystick.
    FixBot'a Sor
    Yorum Ekle
  5. Miadore Classic N64 Controller Buttons Replacement, Buttons: adım 5, 3 resimden 1. Miadore Classic N64 Controller Buttons Replacement, Buttons: adım 5, 3 resimden 2. Miadore Classic N64 Controller Buttons Replacement, Buttons: adım 5, 3 resimden 3.
    • Remove the right and left bumper.
    • If the bumper buttons are the buttons that need to be replaced, you can stop here.
    FixBot'a Sor
    Yorum Ekle
  6. Miadore Classic N64 Controller Buttons Replacement: adım 6, 3 resimden 1. Miadore Classic N64 Controller Buttons Replacement: adım 6, 3 resimden 2. Miadore Classic N64 Controller Buttons Replacement: adım 6, 3 resimden 3.
    • Pull the motherboard up with even pressure on all sides.
    • Set the motherboard to the side.
    FixBot'a Sor
    Yorum Ekle
  7. Miadore Classic N64 Controller Buttons Replacement: adım 7, 3 resimden 1. Miadore Classic N64 Controller Buttons Replacement: adım 7, 3 resimden 2. Miadore Classic N64 Controller Buttons Replacement: adım 7, 3 resimden 3.
    • Remove the rubber gaskets.
    • This will reveal the buttons underneath.
    FixBot'a Sor
    Yorum Ekle
  8. Miadore Classic N64 Controller Buttons Replacement: adım 8, 2 resimden 1. Miadore Classic N64 Controller Buttons Replacement: adım 8, 2 resimden 2.
    • Push up from the bottom of the controller to pop the buttons out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
angel villagomez
313 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-3, Kershman Fall 2024 CSU Los Angeles, Team 5-3, Kershman Fall 2024 üyesi
CSULA-KERSHMAN-F24S5G3
5 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 390
