Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Place the watch on your wrist and determine whether links should be added or removed.
If watchband needs to be expanded, approximate the number of links required.
Set the watch on the block holder.
Ensure the arrows located on the links are pointing downward.
When removing damaged or extra links, hold one end of the pin pusher against the pin to be removed.
Strike the other end of the pin pusher with the metal side of the watch hammer until the pin slides out.
Discard the broken links or save any extra links that you remove.
To add links to the watchband, position the watch on the block holder with the arrows facing upward.
Insert pins into the holes that connect the new link to the rest of the watchband.
Use the soft side of the hammer to strike the pin down.
Lastly, make sure that all the pins joining the links are secured in place.
7 farklı kişi bu kılavuzu tamamladı.
9 Yorum
How do I replace a broken link when it's the very first link that connects the band to the actual watch?
How can I puchace the first link on my Michael kors ceramic watch
I need first link to attach to micheal kors ceramic white watch
The lady when I bought my watch at the mall told me that Michael Kors will give you two free links I'm trying to figure out how I can go about getting that
Where can I get the white bands that cover the links on my my watch as a few have bits broken
