Giriş
This guide will show you how to dissemble the microphone. Before you start you need to have a set of screw drivers (Philips head #00, #2, #0). To reassemble the microphone just reverse the steps.
For names of the microphone parts, please click below:
Microphone Parts' Manual
  1. Remove the windscreen. Using the Phillips head (#00) screwdriver, unscrew the diaphragm from the bottom base of the microphone.
    • Remove the windscreen. Using the Phillips head (#00) screwdriver, unscrew the diaphragm from the bottom base of the microphone.
  2. Separate the microphone into two pieces to reveal the internal shield cover.
    • Separate the microphone into two pieces to reveal the internal shield cover.
    • By unscrewing in a clockwise motion remove the bottom base of the microphone.
    • This should free up the bottom base so that it can be separated from the microphone.
    • Using the Phillips head (#2) screwdriver, remove screw directly above the battery by rotating counterclockwise.
    • Using the Phillips head (#0) screwdriver to remove the black screw near the bottom of the microphone.
    • Use the heavy duty spudger to detach the grip area from the microphone. The inside of the diaphragm should now be visible.
Sonuç
Ekli Belgeler
Kefaya
343 İtibar
3 adet Kılavuz yazıldı
Takım
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 22
Son 30 Gün: 115
Her zaman: 3,128
