Ana içeriğe geç
Microsoft Band 2 Battery Replacement
Neye ihtiyacın var
  1. Microsoft Band 2 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Peel back the metal cover on the end of the watchband.
    use heat to soften the glue and if you are gentle, you will be able to save the cover.
    Joseph DeVaney - Yanıt
  2. Microsoft Band 2 Battery Replacement: adım 2, 1 resimden 1.
    • Use a T3 Torx screwdriver to unscrew the four 6 mm screws on the corners of the metal cover plate.
  3. Microsoft Band 2 Battery Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to pry off the metal cover plate.
  4. Microsoft Band 2 Battery Replacement: adım 4, 2 resimden 1. Microsoft Band 2 Battery Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Detach the black ribbon cable by using the tweezers.
  5. Microsoft Band 2 Battery Replacement: adım 5, 2 resimden 1. Microsoft Band 2 Battery Replacement: adım 5, 2 resimden 2.
    • Detach the orange press-fit (or "pop") connector by using the tweezers.
  6. Microsoft Band 2 Battery Replacement: adım 6, 2 resimden 1. Microsoft Band 2 Battery Replacement: adım 6, 2 resimden 2.
    • Pry out the battery using the plastic opening tool.
    Any source for the battery?
    I've been waiting for someone to post something like this. Thank You
    Bob Grosh - Yanıt
    Try to search in ebay, i don't be able to post link with this battery because the system marked it like spam...
    campy - Yanıt
    Did anyone do this get a battery and have any luck. I just took mine apart and wondering if it is worth $30 for a battery
    p_a_mckenzie - Yanıt
    Yes, I did this and it worked perfectly fine. The hard part is finding the right battery.
    Kyle Vest - Yanıt
    Found the battery on ebay for $20. 1ICP6/18/24 is the part to search for
    hello i just took the battery off and put a new one. i think that the black ribbon cable doesnt reconnect well, since when i put it all back together the watch only show the charging logo and when i unplug it it just turns off. Can anyone help me please ?
    CottonDoux - Yanıt
    Hi, thank you, manuel worked! However, do you have any hint how to best glue the metal plate from the first step? While removing it has been bent a bid. Thank you.
    Midman - Yanıt
    When I opened mine up, the black ribbon cable has split in two, which I guess was my problem in addition to/instead of the battery. Everything else looks fine but where would I even start to fix that? Is a part possible? Any help would be muchly appreciated.
    Adam Shuttleworth - Yanıt
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Chris Syracuse
639 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Leahy Spring 2017 USF Tampa, Team S1-G5, Leahy Spring 2017 üyesi
USFT-LEAHY-S17S1G5
3 Üyeler
5 adet Kılavuz yazıldı
14 Yorum
My Band 2 is not charging and it showing empty battery with AC plugin Icon, but after longtime its not charging . In this case if I replace the battery is it will work or not?
Notes: did not turn on.
Tanvir Ahmed Howlader - Yanıt
Microsoft band guide works well - I managed to remove the battery easily - but where do I get a new battery from ?
Margo Bowes - Yanıt
TWO WORDS:
THANK YOU!
(A++++)
Somebody know where to buy battery replacement?
I Want Fix IT - Yanıt
The only place i found was ebay:
ftlay - Yanıt
Batteries can be found on ebay. I was surprised to see the band come back to life. I found the “pop” connector difficult to align properly. Almost lost patience with it. Got it on, reassembled and it powered up.
Dwight Gaut - Yanıt
Mine will power on but only while its charging. After I take it off the charging cradle it immediately powers off. Do you think the battery replacement will solve this problem? Thanks in advance for any input!
Ashrocque - Yanıt
Brilliant, my band is out of warranty and I could not get the battery charging problem fixed. Purchased a new battery on E-Bay, fitted it using the instructions and the band now works.
Thanks for the post and showing me how to fix the Band.
Malcolm Guy - Yanıt
wie bekommt man das Metall Teil wieder nachher dran kleben
Mika Mclaren - Yanıt
Thanks so much!!!
Tait Berlette - Yanıt
Posted 2018-10-06:
I bought the iFixIt tool kit for this repair, and I was able to do the battery replacement for my Band 2 per the instructions (thank you iFixIt!). But unfortunately my Band 2 still wouldn’t charge, I just continue to get that “empty battery” icon for hours on end (and one teeny-tiny blue pixel blinks at the bottom left corner of the display).
I use the same wall charger to successfully charge my Bluetooth headsets every day, so I know the USB power supply/wall charger I’m using is good. But after checking all pin combinations of the five pins on the cradle end of my Band 2 charging cable, all five pins are 0 (zero) VDC. I even got two small but strong magnets and placed them on the cradle, in case it requires the magnetic coupling to enable the 5 VDC to get through to the pins, but still no voltage at any of the five pins on the cradle. Does anyone know if it is or is not the case that the Band 2 charging cradle does not energize any pins unless the watch is docked?
Raymond Bishop - Yanıt
I have exactly the same result.
madcap -
Raymond Bishop You might have destroyed your watch/battery if you did not ground yourself or wash your hand properly and dawn gloves…
Daniel Hamilton - Yanıt
After I destroyed one Band trying to fix it I bought another one on ebay. 2 Weeks in and now it does not load… I thought the battery was dead and tried replacing it. Sadly it does not seem to have worked since the problem still shows and I somehow would guess that the “black ribbon cable“ is partly to blame since I have no clue how to line it up properly. The Band part does not seem to have any obvious breakage…
Jan Henning Klasen - Yanıt
Anyone any ideas left? *desperate*
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 12,859
