Ana içeriğe geç
Microsoft Band 2 Buttons Replacement
Neye ihtiyacın var
  1. Microsoft Band 2 Buttons Replacement, Screen: adım 1, 1 resimden 1.
    • Wear proper gloves when using a heatgun.
    • Use a heatgun to melt the adhesive beneath the screen. Heat the metal around edges of the screen.
    • Avoid heating the rubber watch band as it will quickly melt.
    • Heating the LCD screen may damage it. Avoid this procedure unless you intend to replace the screen.
  2. Microsoft Band 2 Buttons Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Spudger
    $2.99
    Satın Al
  3. Microsoft Band 2 Buttons Replacement: adım 3, 2 resimden 1. Microsoft Band 2 Buttons Replacement: adım 3, 2 resimden 2.
    • Use metal tweezers to gently detach the orange press-fit (or "pop") connector.
  4. Microsoft Band 2 Buttons Replacement, Buttons: adım 4, 1 resimden 1.
    • Use the T3 Torx Screwdriver to remove the two 2.7 mm screws
  5. Microsoft Band 2 Buttons Replacement: adım 5, 1 resimden 1.
    • Lift the logic board and locate the two circular clips securing the buttons from inside the wall of the Band 2. Remove them by sliding the clips sideways.
  6. Microsoft Band 2 Buttons Replacement: adım 6, 1 resimden 1.
    • Remove the buttons, being careful not to lose the springs.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chris Syracuse
639 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Leahy Spring 2017 USF Tampa, Team S1-G5, Leahy Spring 2017 üyesi
USFT-LEAHY-S17S1G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,271
