Ana içeriğe geç
Microsoft Band Battery Replacement
Neye ihtiyacın var
    1. Microsoft Band Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Unscrew both side panel 2mm screws using the T3 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Band Battery Replacement: adım 2, 1 resimden 1.
      • Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Band Battery Replacement: adım 3, 1 resimden 1.
      • Gently pry up one edge of the battery with the plastic spudger.
      FixBot'a Sor
      Yorum Ekle
    4. Microsoft Band Battery Replacement: adım 4, 1 resimden 1.
      • Remove battery from its compartment with your fingers.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
5 farklı kişi bu kılavuzu tamamladı.
Monique Salinger
408 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-34, Amido Winter 2015 Cal Poly, Team 17-34, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S17G34
4 Üyeler
12 adet Kılavuz yazıldı
5Kılavuz Yorumları
where can i buy the battery?
chirac - Yanıt Paylaş
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon - Yanıt Paylaş
Will this be dangerous?
Rei zzstu Shiozawa - Yanıt Paylaş
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
Chris Green - Yanıt Paylaş
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
Tomasz Sot - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 50
Her zaman: 12,600
