Giriş
You will need to take apart the Screen Frame, the LCD screen, and the sensor ribbon as a prerequisite to get to the motherboard. You might want to use a magnetic mat to make sure you don't lose the small screws.
Warning: The following guide is likely to ruin the water resistance of the device.
Neye ihtiyacın var
Heat the iOpener. Instructions on how to do this can be found here: iOpener Instructions
Firmly press the frame of the band against the iOpener, and hold it in place for about 90 seconds.
Insert the spudger into the gap under the frame, and lightly slide it about 3/4 of the way down one of the long edges, then repeat with the other.
If the frame doesn't simply pop off, try sliding the spudger the rest of the way down the long edges, and lightly lift the frame with your fingers.
Using the spudger or the plastic opening tool, gently lift the sensor ribbon.
7 farklı kişi bu kılavuzu tamamladı.
