Giriş
You might try keeping track of the screws with the use of a magnetic mat.
Neye ihtiyacın var
Using the T3 Torx Screwdriver, remove the two 2.00mm long screws from the inside of the clasp.
Bir başkası bu kılavuzu tamamladı.
3 Yorum
where can I purchase the replacement part
+1 for Jeepgirlutah
Guide is not for replacing clasp, it just is for removing it... It has no use to remove the clasp while it is still properly attached.
The real question is on how to replace it when it is broken (like ripped off like mine did).
I am a broken the strap where it holds the small piece of metal. I need a new belt spare? thanks and regards
