Ana içeriğe geç
Microsoft Lumia 435 LCD Display Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Microsoft Lumia 435 LCD Display Replacement, Back Cover: adım 1, 3 resimden 1. Microsoft Lumia 435 LCD Display Replacement, Back Cover: adım 1, 3 resimden 2. Microsoft Lumia 435 LCD Display Replacement, Back Cover: adım 1, 3 resimden 3.
    • Switch off the phone.
    • Remove the battery and any inserted SIM and memory cards.
    • Use a screwdriver Torx T6 and remove the 4x black screws.
  2. Microsoft Lumia 435 LCD Display Replacement: adım 2, 3 resimden 1. Microsoft Lumia 435 LCD Display Replacement: adım 2, 3 resimden 2. Microsoft Lumia 435 LCD Display Replacement: adım 2, 3 resimden 3.
    • There are several plastic locking clips hold the back cover to the frame.
    • Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
  3. Microsoft Lumia 435 LCD Display Replacement, Logic board: adım 3, 3 resimden 1. Microsoft Lumia 435 LCD Display Replacement, Logic board: adım 3, 3 resimden 2. Microsoft Lumia 435 LCD Display Replacement, Logic board: adım 3, 3 resimden 3.
    • Unhook:
    • the touch screen flex cable
    • the LCD Display flex cable
    • Use a plastic tool lift up and remove the Logic board.
  4. Microsoft Lumia 435 LCD Display Replacement: adım 4, 2 resimden 1. Microsoft Lumia 435 LCD Display Replacement: adım 4, 2 resimden 2.
    • This is the logic board / main board - a front and rear view.
  5. Microsoft Lumia 435 LCD Display Replacement, LCD Display: adım 5, 3 resimden 1. Microsoft Lumia 435 LCD Display Replacement, LCD Display: adım 5, 3 resimden 2. Microsoft Lumia 435 LCD Display Replacement, LCD Display: adım 5, 3 resimden 3.
    • The Display metal shield is locked to the frame by 4x locking clips.
    • Use a tool with a sharp tip and careful unlock them and remove the shield.
  6. Microsoft Lumia 435 LCD Display Replacement: adım 6, 3 resimden 1. Microsoft Lumia 435 LCD Display Replacement: adım 6, 3 resimden 2. Microsoft Lumia 435 LCD Display Replacement: adım 6, 3 resimden 3.
    • The display is stuck tovthe touch screen glass with a double-sided adhesive tape.
    • Use a hair dryer or hot air gun and worm the glass to make adhesive soften.
    • Distort the frame a little and use a thin plastic tool to separate the display from the frame.
  7. Microsoft Lumia 435 LCD Display Replacement: adım 7, 1 resimden 1.
    • The display is very fragile, do the separation very carefully.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
ZFix
191.308 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.535 adet Kılavuz yazıldı
2 Yorum
كيف اقوم بفك الهاتف وفحص الخلل الذي يوجد فيه .اعني ان هاتفي لا يقبل العمل اظن انه محروق كيف افحصه ؟
How do I remove the phone and to inspect the defect in which the .ani there is a telephone that does not accept the work I think it's seared how it checked ?
mohammad7salaheddin - Yanıt
I am pretty sure he didn’t use ifixit stuff to fix the screen, lmao
mario rados - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 3,221
