Ana içeriğe geç
Microsoft Lumia 535 - Factory Reset, Screen Lock Removal
Videoya Genel Bakış
  1. Microsoft Lumia 535 - Factory Reset, Screen Lock Removal, Microsoft Lumia 535 - Factory Reset, Screen Lock Removal: adım 1, 3 resimden 1. Microsoft Lumia 535 - Factory Reset, Screen Lock Removal, Microsoft Lumia 535 - Factory Reset, Screen Lock Removal: adım 1, 3 resimden 2. Microsoft Lumia 535 - Factory Reset, Screen Lock Removal, Microsoft Lumia 535 - Factory Reset, Screen Lock Removal: adım 1, 3 resimden 3.
    • Switch off the phone.
    • Press and hold the Volume Down button and connect your charger. When you see an exclamation mark release the button.
    • Now press the keys in this sequence:
    • Volume Up
    • Volume Down
    • Power
    • Volume Down
    • The phone will reset and reboots.
    Thanks buddy:)
    Akabri Dhaval - Yanıt
    Please help me i have problem resrting my phone..
    kier jumento - Yanıt
    Are you really?
    eyobe - Yanıt
    what a great Method .it work ........... thankx for genius method
    usmanmanga85 - Yanıt
    please help, I just did the hard reset but now it's denying my microsoft account login...
    i did the reset but failing to login my account and now I cant do anything. Im stuck on the sign in page...
    Chido Marufu -
    i did reset but now cant login and cant access anything...
    Chido Marufu -
    Chido Marufu -
    my phone cant touch anymore i hve microsoft mobile rm-1089.after hard reset the phone reboot and stuck at language selection no touch at all been hard resetting over and over. .any help?
    bedelfever - Yanıt
    bhai mayra nhi ho rha
    ns890157 - Yanıt
    it worked thnks ilove the tips
    dex vin - Yanıt
    Approximately how much time is it supposed to take?
    Aashka Vora - Yanıt
    This not working what else can I do?
    Oluwakemi - Yanıt
    Thank you so much you r great. I have done.....thanks
    Rakshit - Yanıt
    fantastic.Thank you so much
    Kirti Sethia - Yanıt
    fantastic.Thank you
    Awesome…Thank You so much…
    Bipin Bihari Sethi - Yanıt
    After I press the volume down key and insert my charger no exclamation mark appears so what do I do??
    Richard Donkor - Yanıt
    I am re start the phone as per instructions but the phone will not be open.
    Still the exclamation mark appears
    What I do?
    Siva ganesh - Yanıt
    total sucess
    CPI - Yanıt
    I followed the hard reset procedure, but when I press the volume up button, the phone goes off. I have not had the chance of pressing the other buttons. Please help me if there's any other method. Thanks
    Lawrence Kumah - Yanıt
    Very well... Thank you...
    Ankita Kar - Yanıt
    How do i cancel the hard reset?
    Yadira Ruiz - Yanıt
    Smash it! Hard on the ground. Quick.
    Edgar Cintron -
    Thanks exellent!
    sunethwbs - Yanıt
    resetting in progress. Thanks
    Benjamin Bara - Yanıt
    wa za mara da kho mata yada wa
    niamatullah123 - Yanıt
    good and easy mode.
    thanks a lot
    MAHAM NAZIR - Yanıt
    I did reset but my restoration code isn't received. Same phone number and email address but still have not been able to receive code. Please help. How will I receive code. I'm checking my email for code. No text message received yet.
    Arabi - Yanıt
    It really worked. Thanks for the post
    braphord saunders oliver - Yanıt
    Thanks it works and make sense
    HAMMED ALAGBE - Yanıt
    Thank a lot, its working.
    P Gana - Yanıt
    Volume up button is not working…. Any other way of reset my phone??
    Raja 12345 - Yanıt
    I can’t install any app on my windows phone
    Chaudary Ibrar - Yanıt
    I did get the exclamation point symbol but now it has more of a lighting bolt w the settings symbol. Can't do anything to it now? Please reply. I appreciate the help so far.
    miranda hackford - Yanıt
    Has anyone recieved any reply back?
    You sir are a beast.. Beautiful.. It work for me.. Thanks! Edgar lynn ma..✌
    Edgar Cintron - Yanıt
    Thanks. It worked
    Atul Chawathe - Yanıt
Sonuç
Your device is now reset!
193 farklı kişi bu kılavuzu tamamladı.
ZFix
191.278 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
112 Yorum
thanks a lot!!
very useful!
suchitra kumar - Yanıt
You are mouthed
Idris - Yanıt
THankx for your help..
Pinak - Yanıt
but my mobile timeing was 107 and this step are not work that
shahaji jadhav - Yanıt
same with me.
can you help me? I try the step but is not work in my mobile timing is 790880. how to remove those screen password?
Alden Hammisain -
worked for me...thanks
erick - Yanıt
It really worked for my Microsoft Lumia 535. Thanks
Tiamiyu Babatunde - Yanıt
how did you do it because mine turning on as soon as l press the volume up button
alfredjunior -
Thanks A lot. Saved my day
Shivam Jain - Yanıt
When i press that button nothing happen to the phone it only starts..
When i press that button the phone starts and nothing happen
did your work out
alfredjunior -
thanks, worked for me
Humphrey Tamata - Yanıt
when I followed what you have stated, my phone could not load up the exclamation mark but shows battery charging sign
jobstevegimisimo - Yanıt
Answer to skipping ! Symbol and going straight to battery charging symbol?
Albert einstine -
Good Way Thankx.......
Shahid Muhammad - Yanıt
It worked greatly thank you very much it is greatly greatly appreciated it was just as simple as it is explained!!!
Tifani Hill - Yanıt
worked for me thanks man.
Will Hanson - Yanıt
thank you very much for a wonderful solution.
satya033 - Yanıt
i followed the same instructions, but when I press the start button my phone switches on and goes back to the password locked screen.
Jyoti Raj - Yanıt
Thats what mine is doing did u find a solution
Shamekia Mitchell -
Thank you...saved my time
Fredrick Omondi - Yanıt
Não resultou... Fica em loop mostrando as engrenagens e depois uma carinha triste
Que posso fazer para voltar a ligar o telemóvel??
andreiapanatal83 - Yanıt
You knw Actually the lock has been broken but i duano what is next step mean while it's asking to fix some point for which look forward to get this done.
Akash Kumar - Yanıt
%#*@ it actually worked
Alex Teano - Yanıt
it is not working on my phone pls tell me another solution
AJITH TV - Yanıt
thank you bro........
laltu chowdhury - Yanıt
very useful guide
haprotege2020 - Yanıt
Thanks for your very good information
b17karthik - Yanıt
did we lost win 10 switch back to win 8.1 from win10 after factory reset?
my lumia 535 face screen freeze and some time auto power off and power button not working problem
when I press power button it show dim light and black screen again and also got heat up from upper front back side
the only thing work in these issue is remove back cover put off battery put in again
hasan_rameez - Yanıt
Very Useful.........
gauravmalikbro - Yanıt
Genius and bravo
Alabi Tajudeen - Yanıt
The author did an excellent job that deserves commendation.The steps were so easy and straight forward
good on ya mate thanks for trick
emreozcicekci - Yanıt
thank you very much
charlotte1986charlie - Yanıt
Wow thank u my IT It's work for me from Ernest tnx an tnx again my god bleessd u
bongs_72 - Yanıt
Tnx my IT its worked for me
bongs_72 - Yanıt
lumia 535 copied recovering mode
ashleys69 - Yanıt
thanks to ya, it really worked............. thanks to the crew
bi jay - Yanıt
Chido Marufu - Yanıt
It works for me lumia 540 thanks a lot....for your valuable suggestion..
Raghu Raghu - Yanıt
Thanks a lot it really work for me......kudos
philipbrown6743 - Yanıt
I try it but it really really and extremely work for me thanks a lot
awesome it really works. thanks alot
henry fundi - Yanıt
My phone appears (try again in 1034387 minutes) and could not open. Please help me. URGENT
chenthin707 - Yanıt
Thaaaaaank Youuuuuu soooo mucccchhh
Alber Einstein - Yanıt
This process is fully working if Your touch is Not working
It's like a GTA cheat code from the ps2 days, btw it worked for me :<}
Shaquille Richards - Yanıt
Thanks It worked
lasherrika - Yanıt
My friend asked me to unlock it, I just tried in search engine. It helped me at right..
Haridass - Yanıt
It worked thank ya vry much amigo
Abdullah Twait - Yanıt
thanks alot it helped.
Jolandie Klein - Yanıt
did that, saw the gears then went to a sad smiley, please help.
Mharc - Yanıt
Bohat bohat shukriya
gangaram kore - Yanıt
thank you sooooooooooooooooooooooooooooooooo much
IHSAN ULLAH - Yanıt
can I do that on my phone but it has no power
Nash Rutsate - Yanıt
please help, can I do that on a powerless phone
It is working but after reset edge browser is missing old help me
Prashanth D - Yanıt
Cool! Other remember to remove you sceenlock first before trying this, then it will work/
Liam Decker - Yanıt
My phone is reset but its asking reset protection key. What can i do
Uday Urs - Yanıt
how much time it should take to reboot and start
VANDAN NAGAR - Yanıt
Whats the answer to the timeframe regaurding how long does it take fof the reset to take?
Albert einstine -
Whats the eta for reset
Albert einstine -
Thanks to the author, for his excellent work.
aparesh datta - Yanıt
Thanks to the author for his excellent work.
Not working for me. Pls help to reset password.
Bhuvana Vaithilingam - Yanıt
This method Not working for me. Phone only starts. Pls help me.
Thanks…..very helpful
Lahiru Wijewardana - Yanıt
My mircosoft windows phone will not factory reset
Louise Hopson - Yanıt
You are really genious bro… Awesome…
Thanks and it works for me very nicely…
Md. Mehedi Hassan Shawon - Yanıt
You are a guru, genius, in fact Einstein….. thanks a lot
Dhermy Machessy - Yanıt
You,re great !!!!!!!!!!!
keep it going. Love you, May God bless you Sir
Raj Kamal - Yanıt
Cheers man…it worked. God bless
samuel kalel - Yanıt
Good work! works like a charm!
qash miik - Yanıt
Awesome! I'm overjoyed, the steps were
Kameswari - Yanıt
If it failed for you try it this way without the charger: Press the power button to start and when it vibrates hold the volume down button until it shows you the exclamation mark. the do the volume up down power down sequence mentioned above here and leave it aside to show the logo then spinning cog wheels. The charge route failed for me too till i found the route where you dont include the charger.
romeohammer3 - Yanıt
My didnt work at all
Katy Hudson - Yanıt
The reset worked but it is asking for a reset protection recovery key that I am not able to get
Debbie Reid-Jones - Yanıt
Thank you vry vry much…
vinod Tolani - Yanıt
thank’s dude worked bang on……
mizer006 - Yanıt
it’s working.. although we have it trial and error, and thank to you…
rotsennoziuk - Yanıt
Thank so much it really work perfectly for me
aisivbiekpen - Yanıt
thanks you so much.. you are awesome …..
tejipta - Yanıt
phone restarts when i hold volume down
can’t reset
Shubham Sharma - Yanıt
Very useful & easy
Amitanshu Ranjan - Yanıt
you are good lumia, great job done
ANANIVI EMMANUEL 18-10-2014 - Yanıt
thanks bhai success
RAM CHANDRA (RAJ) - Yanıt
thanks work for me
eddie cen - Yanıt
thank you. my friend lost her phone so she’s going to use her previous phone and ask me to do a hard reset. great help dude!
milenyume_gyrl_23 - Yanıt
Very easy, very useful
sandyinkx3 - Yanıt
Omg….Your my HERO! :-)
Shelby Jean - Yanıt
HI Team,
My phones touch is not working since last night…please help
Shyam Sunder - Yanıt
mine is refusing to go to the main menu
lucienne.lune - Yanıt
what should i do
you can also reset your lumia by going into settings, scroll down and chose about phone in there it gives you the option to reset phone click on and you will be prompted are you sure press OK and it will shut down and when it restarts it will show 2 cogs turning this take about 2/3 minutes, you now have your phone back to factory set. hope this helps those who could not do it the other way?
Klite - Yanıt
It’s been 1 hour and the wheels are still rotating. What should i do? :( :( :( :(
Alim Al Razi - Yanıt
great help. now i can use my phone again . i love the feathers but soon it will be dead as microsoft unable to tap the market potential of windows phones any more
khaniftikhar761 - Yanıt
super reset method of mobile .
Dattaraj Naik- 10-09-2019
Dattaraj Naik - Yanıt
Wow!! It really worked like a charm.. thanks for sharing this
Ricky Ross - Yanıt
Volume up button not working…. Any other way of reset my phone???
Raja 12345 - Yanıt
Done this but the former owner had the reset protection on and now it wants the recovery key
Stanford Adams - Yanıt
While the update is underway, the outbreak has come to an end. Then a mark comes up on a display
Sasikaran Sakilan - Yanıt
Thank you this was extremely easy . I have this as a back up phone . I dropped my Galaxy S10e and destroyed the screen I had forgotten the pin lock on this one and needed a fully operable phone for the next few days while I wait on my replacement from the insurance.
Sanity is restored
Kelli Martin - Yanıt
When exclamation mark appears and i press Volume Up button. exclamation mark disappears before even I press volume down button
Syed Azaz Ul Hassan - Yanıt
मेरे फोन में इस गतिविधि से चरखा सा चलने लगा
Vikas Sheoran - Yanıt
grazie infinite, ho resettato il Lumia 535 con molta facilità di nuovo grazie!!!!
drapar - Yanıt
Badass that work as explained
juggalojerm19 - Yanıt
Thanks for help but it takes so much time
Prajwal Mahadik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 48
Son 30 gün: 170
Her zaman: 388,372
