Ana içeriğe geç
Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Back Cover / Rear Case: adım 1, 2 resimden 1. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Back Cover / Rear Case: adım 1, 2 resimden 2.
    • Turn off the phone.
    • Remove the battery and any SIM and memory cards.
  2. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: adım 2, 2 resimden 1. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: adım 2, 2 resimden 2.
    • With a screwdriver Torx T4 remove the 9x screws.
  3. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: adım 3, 3 resimden 1. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: adım 3, 3 resimden 2. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: adım 3, 3 resimden 3.
    • With a plastic opening tool separate the back cover from the middle frame.
  4. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: adım 4, 3 resimden 1. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: adım 4, 3 resimden 2. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: adım 4, 3 resimden 3.
    • Disconnect:
    • Touch screen flex cable
    • LCD Display flex cable
    • Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
    • Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
    • Remove the 2x Torx T4 screws.
  5. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: adım 5, 3 resimden 1. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: adım 5, 3 resimden 2. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: adım 5, 3 resimden 3.
    • Insert wisdom here.
  6. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: adım 6, 3 resimden 1. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: adım 6, 3 resimden 2. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: adım 6, 3 resimden 3.
    • Disconnect the coaxial antenna cable.
    • The cable is attached at several points to the frame and to the board. Gently remove it.
  7. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: adım 7, 3 resimden 1. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: adım 7, 3 resimden 2. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: adım 7, 3 resimden 3.
    • The board is glued to the main frame by adhesive tape.
    • Use a hot gun or hair dryer and warm the board.
    • Now you can easy separate the board from the main frame.
    • For the separation process use only plastic tools.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
ZFix
191.278 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
Bir Yorum
where can i get charging port for microsoft lumia 540
saurabh pawar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 14,760
