Giriş
RM-1090 / RM-1091/ RM-1089 / RM-1092
How to fully disassemble Microsoft Lumia 535 to replace broken screen, loudspeaker, earpiece, charging dock board, etc.
Neye ihtiyacın var
Videoya Genel Bakış
Turn off the phone.
Remove the battery and any SIM and memory cards.
Disconnect:
Touch screen flex cable
LCD Display flex cable
Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
Remove the 2x Torx T4 screws.
From the old display Assembly we have to move:
Earpiece
Proximity sensor rubber
LCD flex cable Rubber
Coaxial Antena Cable
Small board with the Charging port and Mic.
The board is glued to the main frame by adhesive tape.
Use a hot gun or hair dryer and warm the board.
Now you can easy separate the board from the main frame.
4 farklı kişi bu kılavuzu tamamladı.
