Ana içeriğe geç
Microsoft Lumia 535 Logic board Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Microsoft Lumia 535 Logic board Replacement, Back Cover / Rear Case: adım 1, 2 resimden 1. Microsoft Lumia 535 Logic board Replacement, Back Cover / Rear Case: adım 1, 2 resimden 2.
    • Turn off the phone.
    • Remove the battery and any SIM and memory cards.
  2. Microsoft Lumia 535 Logic board Replacement: adım 2, 2 resimden 1. Microsoft Lumia 535 Logic board Replacement: adım 2, 2 resimden 2.
    • With a screwdriver Torx T4 remove the 9x screws.
  3. Microsoft Lumia 535 Logic board Replacement: adım 3, 3 resimden 1. Microsoft Lumia 535 Logic board Replacement: adım 3, 3 resimden 2. Microsoft Lumia 535 Logic board Replacement: adım 3, 3 resimden 3.
    • With a plastic opening tool separate the back cover from the middle frame.
  4. Microsoft Lumia 535 Logic board Replacement, Logic board: adım 4, 3 resimden 1. Microsoft Lumia 535 Logic board Replacement, Logic board: adım 4, 3 resimden 2. Microsoft Lumia 535 Logic board Replacement, Logic board: adım 4, 3 resimden 3.
    • Disconnect:
    • Touch screen flex cable
    • LCD Display flex cable
    • Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
    • Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
    • Remove the 2x Torx T4 screws.
  5. Microsoft Lumia 535 Logic board Replacement: adım 5, 3 resimden 1. Microsoft Lumia 535 Logic board Replacement: adım 5, 3 resimden 2. Microsoft Lumia 535 Logic board Replacement: adım 5, 3 resimden 3.
    • Insert wisdom here.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
ZFix
191.278 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
4 Yorum
How can I add additional sensors- the gyroscope & compass chips on this logic board?
Abinash Pal - Yanıt
microsoft lumia 535 chargeing ic complete
Sunitha Kunapareddi - Yanıt
my Microsoft lumia 535 chargeing ic complient main mother board lo problem
My microsoft mobile 1090 is not displaying apps but on backlight
Please what can I do to it?
aribasoyeifeoluwa - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 5,930
