Ana içeriğe geç
Microsoft Lumia 640 LTE Screen Replacement
Neye ihtiyacın var
  1. Microsoft Lumia 640 LTE Screen Replacement, Back Cover: adım 1, 2 resimden 1. Microsoft Lumia 640 LTE Screen Replacement, Back Cover: adım 1, 2 resimden 2.
    • Use your thumb or fingernail on the edge/corner of the phone to pry the back cover off the phone.
  2. Microsoft Lumia 640 LTE Screen Replacement, Screen: adım 2, 3 resimden 1. Microsoft Lumia 640 LTE Screen Replacement, Screen: adım 2, 3 resimden 2. Microsoft Lumia 640 LTE Screen Replacement, Screen: adım 2, 3 resimden 3.
    • Use the tweezers to pull back the sticker, revealing the screw underneath.
    • Be careful when removing the screws as they can strip easily.
  3. Microsoft Lumia 640 LTE Screen Replacement: adım 3, 2 resimden 1. Microsoft Lumia 640 LTE Screen Replacement: adım 3, 2 resimden 2.
    • Use a T4 Torx driver to remove the screws in the four corners, along with the two in the middle left side (six total).
  4. Microsoft Lumia 640 LTE Screen Replacement: adım 4, 2 resimden 1. Microsoft Lumia 640 LTE Screen Replacement: adım 4, 2 resimden 2.
    • Using the T4 Torx driver, unscrew the two screws.
    • Keep these screws separate from the screws from back of the phone to ensure that the right screws go where they belong.
  5. Microsoft Lumia 640 LTE Screen Replacement: adım 5, 2 resimden 1. Microsoft Lumia 640 LTE Screen Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to separate the screen from the back plastic casing
    • Use tweezers to release the clip on the side of device, and remove the back of the phone.
  6. Microsoft Lumia 640 LTE Screen Replacement: adım 6, 2 resimden 1. Microsoft Lumia 640 LTE Screen Replacement: adım 6, 2 resimden 2.
    • Using the tweezers or a spudger, pull the gold tab up gently.
    • Using tweezers or a spudger, lift the white connector up gently to completely detach the screen from the phone.
    • For motherboard replacement, skip to Step 11 after finishing this step.
  7. Microsoft Lumia 640 LTE Screen Replacement: adım 7, 3 resimden 1. Microsoft Lumia 640 LTE Screen Replacement: adım 7, 3 resimden 2. Microsoft Lumia 640 LTE Screen Replacement: adım 7, 3 resimden 3.
    • Using a plastic opening tool to carefully get under the gold strip.
    • Use tweezers to pull up the camera.
    • Use tweezers to pull up on the depth sensor.
    • This is held in by a strong adhesive.
  8. Microsoft Lumia 640 LTE Screen Replacement: adım 8, 1 resimden 1.
    • Use a plastic opening tool to pry up the ear speaker.
    • This is held in by strong adhesive.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 15
Her zaman: 874
