Ana içeriğe geç
Microsoft Lumia 640 XL Touch Screen Replacement
Neye ihtiyacın var
  1. Microsoft Lumia 640 XL Touch Screen Replacement, Battery: adım 1, 3 resimden 1. Microsoft Lumia 640 XL Touch Screen Replacement, Battery: adım 1, 3 resimden 2. Microsoft Lumia 640 XL Touch Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Place left palm on screen and right palm on the back.
    • Press down with fingertips and pull to separate the back from the screen.
    • You may hear cracking and popping.
  2. Microsoft Lumia 640 XL Touch Screen Replacement: adım 2, 2 resimden 1. Microsoft Lumia 640 XL Touch Screen Replacement: adım 2, 2 resimden 2.
    • Lift the battery away from the phone with the flat side of a spudger.
    • Be careful not to damage the battery.
  3. Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: adım 3, 3 resimden 1. Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: adım 3, 3 resimden 2. Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: adım 3, 3 resimden 3.
    • Remove all ten T3, 4.09 mm screws.
    • Lift mid-frame assembly from phone with flat side of a spudger.
  4. Microsoft Lumia 640 XL Touch Screen Replacement: adım 4, 3 resimden 1. Microsoft Lumia 640 XL Touch Screen Replacement: adım 4, 3 resimden 2. Microsoft Lumia 640 XL Touch Screen Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift and peel connector away from phone using tweezers.
    • To re-attach you may need E6000 Adhesive Glue.
  5. Microsoft Lumia 640 XL Touch Screen Replacement, Motherboard: adım 5, 2 resimden 1. Microsoft Lumia 640 XL Touch Screen Replacement, Motherboard: adım 5, 2 resimden 2.
    • Remove all three T3, 2.66 mm screws.
  6. Microsoft Lumia 640 XL Touch Screen Replacement: adım 6, 3 resimden 1. Microsoft Lumia 640 XL Touch Screen Replacement: adım 6, 3 resimden 2. Microsoft Lumia 640 XL Touch Screen Replacement: adım 6, 3 resimden 3.
    Satın Al
    • Lift off connector with tweezers.
    • Lift motherboard off with tweezers and pull away with fingers.
  7. Microsoft Lumia 640 XL Touch Screen Replacement, Touch Screen: adım 7, 2 resimden 1. Microsoft Lumia 640 XL Touch Screen Replacement, Touch Screen: adım 7, 2 resimden 2.
    • Remove the screen from the device.
    • Touch screen digitizer and screen glass are one unit.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 1,208
