Ana içeriğe geç
Microsoft Surface 2 I/O Cable Replacement
Neye ihtiyacın var
    1. Microsoft Surface 2  I/O Cable Replacement, Screen: adım 1, 3 resimden 1. Microsoft Surface 2  I/O Cable Replacement, Screen: adım 1, 3 resimden 2. Microsoft Surface 2  I/O Cable Replacement, Screen: adım 1, 3 resimden 3.
      • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
      • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
      • Avoid touching the metal end of the gun. It will be very hot and can burn you.
      • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
      • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface 2  I/O Cable Replacement: adım 2, 3 resimden 1. Microsoft Surface 2  I/O Cable Replacement: adım 2, 3 resimden 2. Microsoft Surface 2  I/O Cable Replacement: adım 2, 3 resimden 3.
      • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
      • Use a plastic spudger to pry the retaining clip away from the display cable.
      • The ribbon cable may be glued to the motherboard.
      • Carefully pull the ribbon cable from its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Microsoft Surface 2  I/O Cable Replacement, I/O Cable: adım 3, 2 resimden 1. Microsoft Surface 2  I/O Cable Replacement, I/O Cable: adım 3, 2 resimden 2.
      • Work close to Magnetic Project Map to avoid losing screws.
      • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
      • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
      • Once all screws have been removed, lift and remove the bezel from the rest of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface 2  I/O Cable Replacement: adım 4, 2 resimden 1. Microsoft Surface 2  I/O Cable Replacement: adım 4, 2 resimden 2.
      • Remove the two 2.19 mm T3 screws that hold down the SD card ribbon cable.
      • Remove the two 3.27 mm T3 screws holding down the charging port.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface 2  I/O Cable Replacement: adım 5, 3 resimden 1. Microsoft Surface 2  I/O Cable Replacement: adım 5, 3 resimden 2. Microsoft Surface 2  I/O Cable Replacement: adım 5, 3 resimden 3.
      • Use a spudger to pry up the retaining plate at the end of the ribbon cable.
      • The retaining chip may be glued to the motherboard.
      • Use the spudger to flip up the small retaining flap on the cable's zero insertion force connector.
      • Make sure you are prying up on the retaining flap, not the connector itself.
      • Remove the ribbon cable from its port.
      • No force is needed to plug in or remove the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Gregory Miller
415 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Wollert Spring 2016 USF Tampa, Team 3-1, Wollert Spring 2016 üyesi
USFT-WOLLERT-S16S3G1
4 Üyeler
20 adet Kılavuz yazıldı
2Kılavuz Yorumları
I want to replace the battery of Microsoft Surface 2, which steps I have to follow to replace it?
Piero Sabino - Yanıt Paylaş
Cosa devo utilizzare per attaccare il cavo del display sotto al fermaglio di distanza, colla o nastro biadesivo?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 54
Her zaman: 5,300
