Ana içeriğe geç
Microsoft Surface 2 Speaker Replacement
Görüntüleme: 2,1 B
İstatistikleri görüntüle:
Son 24 Saat:
4
Son 7 Gün:
24
Son 30 Gün:
100
Her zaman:
2.117
Yorumlar: 5
5 comments on steps.
Tamamlandı: 1
1 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 1
1 kişi bu kılavuzu favorilerine ekledi (ve abone oldu). Sıradaki sen olacak mısın?
Gerekli Süre: 35 - 45 dakika
Zorluk: Kolay
If the speaker is not playing at its optimal level or the audio output seems to be malfunctioning , the speakers most likely need to be changed. Use this guide to replace the speakers in your Microsoft Surface 2 . Make sure to use a standard nylon spudger and not a metal one.
Neye ihtiyacın var
Aletler
    1. Microsoft Surface 2 Speaker Replacement, Screen: adım 1, 3 resimden 1. Microsoft Surface 2 Speaker Replacement, Screen: adım 1, 3 resimden 2. Microsoft Surface 2 Speaker Replacement, Screen: adım 1, 3 resimden 3.
      • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
      • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
      • Avoid touching the metal end of the gun. It will be very hot and can burn you.
      • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
      • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface 2 Speaker Replacement: adım 2, 3 resimden 1. Microsoft Surface 2 Speaker Replacement: adım 2, 3 resimden 2. Microsoft Surface 2 Speaker Replacement: adım 2, 3 resimden 3.
      • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
      • Use a plastic spudger to pry the retaining clip away from the display cable.
      • The ribbon cable may be glued to the motherboard.
      • Carefully pull the ribbon cable from its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Microsoft Surface 2 Speaker Replacement, Speaker: adım 3, 2 resimden 1. Microsoft Surface 2 Speaker Replacement, Speaker: adım 3, 2 resimden 2.
      • Work close to Magnetic Project Map to avoid losing screws.
      • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
      • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
      • Once all screws have been removed, lift and remove the bezel from the rest of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface 2 Speaker Replacement: adım 4, 1 resimden 1.
      • Using a T3 screwdriver, unscrew and remove the 3.5mm screws holding down the silver plates located at the corners of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface 2 Speaker Replacement: adım 5, 2 resimden 1. Microsoft Surface 2 Speaker Replacement: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using tweezers, remove the cable connecting the speaker to the motherboard.
      • Peel up the tiny strip of yellow tape securing the cable to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Microsoft Surface 2 Speaker Replacement: adım 6, 2 resimden 1. Microsoft Surface 2 Speaker Replacement: adım 6, 2 resimden 2.
      • Lifting from the inmost end of the speaker, use a spudger to carefully pry the speaker from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yazar
ile
EG1
612 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Wollert Spring 2016 USF Tampa, Team 3-1, Wollert Spring 2016 üyesi
USFT-WOLLERT-S16S3G1
4 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 100
Her zaman: 2,117
