Giriş
To replace the Surface 3 audio jack, you will need to remove the casing, undo various restraints that keep the audio jack in place, and, finally, remove and replace the audio jack itself.
Neye ihtiyacın var
Warm up an iOpener following the instructions found in the iOpener guide.
Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
Flip the display over so that parts underneath it are easily accessible.
Please note that the WIFI antenna can become stuck to the display. It is located on the black plastic to the right of the camera and can be easily disconnected accidentally. Excellent guide otherwise.
I second this comment. Didn’t know it was there. The surface 3 pro guide clearly warns of this in the takeapart.
You will be working in this area of the Surface 3 when replacing the audio jack and Micro SD port
4 farklı kişi bu kılavuzu tamamladı.
no, I didn't break the screen upon removing batteries.
Robert Hale - Yanıt
