Ana içeriğe geç
Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement
Neye ihtiyacın var
  1. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement, Casing: adım 1, 2 resimden 1. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement, Casing: adım 1, 2 resimden 2.
    • Warm up an iOpener following the instructions found in the iOpener guide.
    • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
    no, I didn't break the screen upon removing batteries.
    Robert Hale - Yanıt
  2. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 2, 2 resimden 1. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 2, 2 resimden 2.
    • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
    • This may take significant force. A fingernail might work better for the initial lift
    • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
  3. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 3, 2 resimden 1. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 3, 2 resimden 2.
    • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
    • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
    Be very careful on the top edge where the front-facing camera is. The antenna’s for all wireless components are pressed into the adhesive on both the right and left of the camera. I tore off a piece of my wifi antenna here.
    Adam Pyle - Yanıt
  4. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 4, 1 resimden 1.
    • Flip the display over so that parts underneath it are easily accessible.
    • Do not pull out the display as it is still attached to the motherboard.
    • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
    Please note that the WIFI antenna can become stuck to the display. It is located on the black plastic to the right of the camera and can be easily disconnected accidentally. Excellent guide otherwise.
    Gary Gleeson - Yanıt
    I second this comment. Didn’t know it was there. The surface 3 pro guide clearly warns of this in the takeapart.
    Brian Carlson - Yanıt
  5. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement, Audio Jack and MicroSD Slot: adım 5, 1 resimden 1.
    • You will be working in this area of the Surface 3 when replacing the audio jack and Micro SD port
  6. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 6, 1 resimden 1.
    • Remove the black adhesive covering next to the audio jack in order to get to the screws underneath.
  7. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 7, 2 resimden 1. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 7, 2 resimden 2.
    • Remove the silver bracket using the black pick in order to properly remove the entire audio jack.
  8. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 8, 2 resimden 1. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 8, 2 resimden 2.
    • Remove the two 3/16" Torx #2 screws directly beside the audio jack.
  9. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 9, 2 resimden 1. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 9, 2 resimden 2.
    • Remove the two 1/16" Torx #3 screws that hold in the MicroSD slot.
  10. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 10, 2 resimden 1. Microsoft Surface 3 Audio Jack and MicroSD Slot Replacement: adım 10, 2 resimden 2.
    • Carefully remove the entire audio jack . It should look like the picture of the single part to the left.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Andy Stone
284 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-12, Maness Fall 2015 Cal Poly, Team 5-12, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G12
4 Üyeler
18 adet Kılavuz yazıldı
2 Yorum
Hi,
What is microsd bus interface? UHS-1 or UHS-2
Or at least, does it have any manufacturer info on it?
kemal - Yanıt
Hi Guys,
Do you know where can I buy mini display port mounted on motherboard? I need aprox 100pcs.
Dan Bach - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 47
Her zaman: 10,281
