Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Warm up an iOpener following the instructions found in the iOpener guide.
Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
Flip the display over so that parts underneath it are easily accessible.
You will be working in this area of the Surface 3 when replacing the audio jack and Micro SD port
Remove the black adhesive covering next to the audio jack in order to get to the screws underneath.
Remove the silver bracket using the black pick in order to properly remove the entire audio jack.
Remove the two 3/16" Torx #2 screws directly beside the audio jack.
Remove the two 1/16" Torx #3 screws that hold in the MicroSD slot.
Carefully remove the entire audio jack . It should look like the picture of the single part to the left.
4 farklı kişi bu kılavuzu tamamladı.
