Ana içeriğe geç
Giriş
Replacing the screen on the Surface 3 is really the only good reason to go about replacing anything in it. You will likely end up breaking the screen and needing to replace it with any of the other replacement guides. This guide may help you to identify how to take it off without breaking it (a major accomplishment).
  1. Warm up an iOpener following the instructions found in the iOpener guide. Place the warm iOpener on top of the edges of the screen.  This heat will weaken the strength of the adhesive between the display and body.
    • Warm up an iOpener following the instructions found in the iOpener guide.
    • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
  2. Use iFixit opening picks to wedge under the edge of the screen at the speaker port. This may take significant force. A fingernail might work better for the initial lift
    • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
    • This may take significant force. A fingernail might work better for the initial lift
    • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
  3. Apple Watch Kitleri
    Screen and battery repairs just got easier.
    Hemen Alışveriş Yapın
    Apple Watch Kitleri
  4. Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck. If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
    • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
  5. Flip the display over so that parts underneath it are easily accessible.
    • Flip the display over so that parts underneath it are easily accessible.
    • Do not pull out the display as it is still attached to the motherboard.
    • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
    Please note that the WIFI antenna can become stuck to the display. It is located on the black plastic to the right of the camera and can be easily disconnected accidentally. Excellent guide otherwise.
    Gary Gleeson - Yanıt
  6. The RF shield that you are about to remove will be damaged in the process. you may be able to bend it back into shape once you remove it. Locate the point where the display is still attached to the motherboard. Use a flat spudger to pry off the RF shielding/bracket retainer.
    • The RF shield that you are about to remove will be damaged in the process. you may be able to bend it back into shape once you remove it.
    • Locate the point where the display is still attached to the motherboard.
    • Use a flat spudger to pry off the RF shielding/bracket retainer.
    • Use a thin guitar pick to release the snap pin from the display to the motherboard.
    • The little black piece (the latch for the ZIF connector) that you have just flipped up is no longer held in place by anything due to Microsoft trying to make the device slimmer. It will fall out and be lost for all eternity unless you carefully keep track of it.
    Don’t use your spudger like in the picture unless you want to destroy the ribbon cable socket.
    Bryan Engelmann - Yanıt
    Then what should you use?
    patrickwalley - Yanıt
    A spudger worked fine for me. As long as you’re careful you should be fine.
    What I did mess up though was the wifi antenna. I was extra extra careful when working on this area but I still managed to break the wifi cable due to the fact that the screen has copious amounts of glue / sticky tape stuck to the top of it which makes it near impossible to remove the screen without causing damage - Way to go Microsoft! >:(
    Clems - Yanıt
Sonuç
28 farklı kişi bu kılavuzu tamamladı.
Harold Hall
1.084 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-12, Maness Fall 2015 Cal Poly, Team 5-12, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G12
4 Üyeler
12 adet Kılavuz yazıldı
9 Yorum
Where can you get replacement screens from?
Gareth - Yanıt
They sell them on this website
Saul Rocha -
is the adhesive that is needed available on this site?
Jaime Grismer - Yanıt
What would happen if that little RF shielding part was not reinstalled?
meric robb - Yanıt
The RF shield both helps prevent the closely packed together components from interfering with each other and also holds in the ZIF connector latch (the little black piece that I warn you not to lose) for the display cable. The results could vary between screen flickering with inconsistent touchscreen performance and the display cable possibly coming lose inside the device and needing to open it up and reattach it. I didn't find it too difficult to bend the RF shield back on, but you may have a harder or easier time.
Harold Hall -
I was involved in a motorcycle accident and my screen was completely cracked. There is also damage to the strip at the bottom where the keyboard attaches.
it opens as usual but the cursor is frozen mid screen and so the touch screen doesn't respond. Is there any way I can access the data / files in the Surface or unfreeze the cursor? I am
in a foreign country and really in a mess without access to my files so any help advise would be a godsend.
Julie kacmaz - Yanıt
Is there anywhere to order the ZIF connectors for the Surface 3 tablets? I currently have one with a broken ZIF connector and can’t seem to find where to order one.
Andrew Iverson - Yanıt
when removing the screen i cut the strips at the top on both sides of the camera, is that the antenna and where can i get that piece it is removable with 6 screws
pbi21 - Yanıt
Hello
My ZIF connector broke with you by chance a reference, so that I could replace it?
tm.alexandrapsn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 Gün: 154
Son 30 Gün: 647
Her zaman: 36,774
