Giriş
In order to replace the Surface 3 tablet's speakers you will have to remove the casing, undo the adhesive that holds the speakers down, and disconnect the speakers from the motherboard.
Neye ihtiyacın var
Warm up an iOpener following the instructions found in the iOpener guide.
Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
You will be working in these areas of the Surface 3 in order to replace the speakers.
