Ana içeriğe geç
Microsoft Surface Book 2 15" Battery Replacement
Neye ihtiyacın var
  1. Microsoft Surface Book 2 15" Battery Replacement, Motherboard: adım 1, 1 resimden 1.
    • Open the laptop, then orient it so the touchpad is on your left.
    • Starting at the hinge, count six holes up on the tablet portion of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Microsoft Surface Book 2 15" Battery Replacement: adım 2, 2 resimden 1. Microsoft Surface Book 2 15" Battery Replacement: adım 2, 2 resimden 2.
    • Take a paper clip and unfold it.
    • Place the paper clip in the sixth hole and push until you hear a click.
    • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
    • After the right side has been detached, lift up the left side as well.
    FixBot'a Sor
    Yorum Ekle
  3. Microsoft Surface Book 2 15" Battery Replacement: adım 3, 1 resimden 1.
    • Place the tablet on a flat surface.
    • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
    FixBot'a Sor
    Yorum Ekle
  4. Microsoft Surface Book 2 15" Battery Replacement: adım 4, 1 resimden 1.
    • Using a plastic pick, slice underneath the edge of the screen.
    • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
    • Take care not to insert the tool too far to avoid cutting the ribbon cables.
    • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
    • Don't use a metal tool, that could damage the screen or internal parts.
    FixBot'a Sor
    Yorum Ekle
  5. Microsoft Surface Book 2 15" Battery Replacement: adım 5, 2 resimden 1. Microsoft Surface Book 2 15" Battery Replacement: adım 5, 2 resimden 2.
    • Lift up the screen.
    • Detach the ribbon cables connecting the underside of the screen to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Microsoft Surface Book 2 15" Battery Replacement: adım 6, 2 resimden 1. Microsoft Surface Book 2 15" Battery Replacement: adım 6, 2 resimden 2.
    • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
    • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
    FixBot'a Sor
    Yorum Ekle
  7. Microsoft Surface Book 2 15" Battery Replacement: adım 7, 1 resimden 1.
    • Once the screws are removed from the top bar, gently lift up and remove it.
    • Be careful not to damage any ribbon cables or wires.
    • Gently lift up on the motherboard to remove it.
    FixBot'a Sor
    Yorum Ekle
  8. Microsoft Surface Book 2 15" Battery Replacement, Battery Removal: adım 8, 2 resimden 1. Microsoft Surface Book 2 15" Battery Replacement, Battery Removal: adım 8, 2 resimden 2.
    • Use an iOpener or a heat gun (on low heat) to carefully heat the back side of the tablet to help soften the battery adhesive.
    • Use prying tools such as a guitar pick, plastic card, or a nylon spudger to help sever the adhesive and gently lift the battery free.
    • After the case cools, a careful amount of isopropyl alcohol can help dissolve stubborn glue between the battery and the case.
    • Work slowly and carefully. Do not pry, bend, or puncture the battery while removing it from the tablet.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Ryan Picewick
537 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Petersen Spring 2023 UMass Dartmouth, Team 3-3, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S3G3
4 Üyeler
23 adet Kılavuz yazıldı
5Kılavuz Yorumları
The first paragraph of this Surface Book 2 battery replacement guide is:
"This guide explains how to replace the battery in the Microsoft Surface Book 2 15". It requires the motherboard replacement guide as a prerequisite guide, which is a very difficult guide to follow without breaking the laptop."
The first paragraph of the motherboard replacement guide is:
This guide is used to explain how to open up the tablet portion of the Microsoft Surface Book 2 15 and gain access to the motherboard. The motherboard of the Microsoft Surface Book 2 15 has a majority of the cables for parts that can be replaced on it.
Does this mean that I have to go through all the replacement motherboard steps and replace the motherboard before replacing the battery?
Nicholas Law - Yanıt Paylaş
You won't need to replace the mobo, but yes, it looks like you'll have to remove it. This guide is pretty confusing right now IMO
darth mango - Yanıt Paylaş
I also find it rather confusing.
Thanks darth mango.
Is it true that the battery in the Surface Book 2 has frequently failed completely?
No charging possible, always 0%.
When a battery ages, you can still charge it to 100%.
Very fast (bad), but “full”.
A total failure would rather be the battery management system.
I wonder if there were also failures of the charging current to the battery, i.e. a defect on the circuit board of the tablet screen.
That would be annoying, of course, because you can't just fix the fault by replacing the battery.
But replacing the entire battery would also be annoying if only the BMS is defective.
All you need is a replacement with comparable values and size, which you solder into the center of the battery.
And what about the assembly?
Are there adhesive strips in this form?
Or should you just use BT-7000 liquid glue?
I bought this for a Samsung Galaxy Note-9 to seal it watertight again after replacing the USB port.
Tobias Claren - Yanıt Paylaş
Meine Akkus sind plötzlich auf 0% hängen geblieben. Aufladen nicht mehr möglich. Nur noch Netzbetrieb meines Surface 2. Schade. Akkutausch zu teuer.
Stefan Schwarz - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 166
Son 30 gün: 774
Her zaman: 35,759
