Ana içeriğe geç
Microsoft Surface Book 2 15" Front Camera Replacement
Neye ihtiyacın var
    1. Microsoft Surface Book 2 15" Front Camera Replacement, Motherboard: adım 1, 1 resimden 1.
      • Open the laptop, then orient it so the touchpad is on your left.
      • Starting at the hinge, count six holes up on the tablet portion of the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Book 2 15" Front Camera Replacement: adım 2, 2 resimden 1. Microsoft Surface Book 2 15" Front Camera Replacement: adım 2, 2 resimden 2.
      • Take a paper clip and unfold it.
      • Place the paper clip in the sixth hole and push until you hear a click.
      • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
      • After the right side has been detached, lift up the left side as well.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Book 2 15" Front Camera Replacement: adım 3, 1 resimden 1.
      • Place the tablet on a flat surface.
      • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
      FixBot'a Sor
      Yorum Ekle
    4. Microsoft Surface Book 2 15" Front Camera Replacement: adım 4, 1 resimden 1.
      • Using a plastic pick, slice underneath the edge of the screen.
      • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
      • Take care not to insert the tool too far to avoid cutting the ribbon cables.
      • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
      • Don't use a metal tool, that could damage the screen or internal parts.
      FixBot'a Sor
      Yorum Ekle
    5. Microsoft Surface Book 2 15" Front Camera Replacement: adım 5, 2 resimden 1. Microsoft Surface Book 2 15" Front Camera Replacement: adım 5, 2 resimden 2.
      • Lift up the screen.
      • Detach the ribbon cables connecting the underside of the screen to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Microsoft Surface Book 2 15" Front Camera Replacement: adım 6, 2 resimden 1. Microsoft Surface Book 2 15" Front Camera Replacement: adım 6, 2 resimden 2.
      • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
      • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
      FixBot'a Sor
      Yorum Ekle
    7. Microsoft Surface Book 2 15" Front Camera Replacement: adım 7, 1 resimden 1.
      • Once the screws are removed from the top bar, gently lift up and remove it.
      • Be careful not to damage any ribbon cables or wires.
      • Gently lift up on the motherboard to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Microsoft Surface Book 2 15" Front Camera Replacement, Front Camera: adım 8, 1 resimden 1.
      • After lifting the motherboard, locate the two cameras near the center of the motherboard.
      • Unplug front camera (right side) from the motherboard (lift carefully).
      FixBot'a Sor
      Yorum Ekle
Sonuç
Colton Almeida
172 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Petersen Spring 2023 UMass Dartmouth, Team 3-3, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S3G3
4 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 841
