Ana içeriğe geç
Microsoft Surface Book 2 15" Keyboard Replacement
Neye ihtiyacın var
  1. Microsoft Surface Book 2 15" Keyboard Replacement, Remove Components: adım 1, 1 resimden 1.
  2. Microsoft Surface Book 2 15" Keyboard Replacement, Remove the Backlight: adım 2, 2 resimden 1. Microsoft Surface Book 2 15" Keyboard Replacement, Remove the Backlight: adım 2, 2 resimden 2.
    • Bring your patience
    • Using the Plastic Scalpel tool (very important it's plastic) and the isopropyl alcohol, maybe a toothbrush to help, and SLOWLY peel off the black sticky backlight from the keyboard.
    • Sorry I do not have a photo/video of this part, but just be slow and slice through the glue do not man handle this take your time.
  3. Microsoft Surface Book 2 15" Keyboard Replacement, Pop-out the Keyboard: adım 3, 2 resimden 1. Microsoft Surface Book 2 15" Keyboard Replacement, Pop-out the Keyboard: adım 3, 2 resimden 2.
    • WARNING: Small Parts fly
    • WARNING: Removing the keyboard will most likely damage it, so only remove it if you have to.
    • Pop the keyboard out, there are pins and they will fly. So turn it as though you were typing onto some sort of cloth to capture the pins.
  4. Microsoft Surface Book 2 15" Keyboard Replacement, New Keyboard and Old Pins: adım 4, 1 resimden 1.
    • There's 40 some different pins, you do not want to lose any if you can help it as it helps the rigidity of your keyboard.
    • Put the pins back you will want a thin small tool that you can push the pins back in. Be careful sometimes putting a pin in can pop another out.
    • It's a good idea to have a magnet on the side too, so that you can test the pins and ensure they're in properly. Check a lot since mine seemed tight but as I put pins in it became loose.
  5. Microsoft Surface Book 2 15" Keyboard Replacement, Replace Backlight: adım 5, 1 resimden 1.
    • Clean the backlight with isopropyl alcohol, it's the clear side, don't clean the sticky off.
    • Use some electrical tape to tape it back in where you need.
Sonuç
FangerZero
331 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 20
Son 30 gün: 105
Her zaman: 2,492
