Ana içeriğe geç
Microsoft Surface RT Kick-stand Replacement
Neye ihtiyacın var
  1. Microsoft Surface RT Kick-stand Replacement, Kick-stand: adım 1, 2 resimden 1. Microsoft Surface RT Kick-stand Replacement, Kick-stand: adım 1, 2 resimden 2.
    • Turn the tablet over so the screen is facing down.
    • Pull up on the bottom corners to open the stand.
    • Remove the stand by unscrewing the two 5.08mm T5 Torx screws located on the left and right sides.
    • Gently wiggle the stand until the lever in the middle is free, releasing the stand.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Kevin Hua
1.612 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-23, Forte Winter 2013 Cal Poly, Team 17-23, Forte Winter 2013 üyesi
CPSU-FORTE-W13S17G23
5 Üyeler
17 adet Kılavuz yazıldı
12 Yorum
Where do you get the replacement kickstand from?
Ray - Yanıt
is this compatible with surface pro 1 ?
arqueiro - Yanıt
Do you offer a replacement kickstand for the surface rt 2?
allie - Yanıt
Does this replacement kickstand come with the screws also?
Andrea Thompson - Yanıt
Where can the kickstand screws be purchased separately?
Anthony Welch - Yanıt
I am in the uk but there no uk options
we love eletronics - Yanıt
Does this work for a broken hinge?
schmee - Yanıt
i need to find the torx #5 screws to mount the kickstand. any suggestions?
Harry - Yanıt
does this fit on a window 8 pro?
JOHN FAVIS - Yanıt
Where can I get the replacement screws from?for surface rt kickstand?
Wishram - Yanıt
Where can i get the replacement screen, for Surface RT 1516 model 64G
mzizijames - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 30
Her zaman: 40,578
