Ana içeriğe geç
Microsoft Surface Laptop 5 (15-inch) Feet Replacement
Neye ihtiyacın var
  1. Microsoft Surface Laptop 5 (15-inch) Feet Replacement, Flip the laptop over: adım 1, 2 resimden 1. Microsoft Surface Laptop 5 (15-inch) Feet Replacement, Flip the laptop over: adım 1, 2 resimden 2.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Microsoft Surface Laptop 5 (15-inch) Feet Replacement, Feet removal information: adım 2, 3 resimden 1. Microsoft Surface Laptop 5 (15-inch) Feet Replacement, Feet removal information: adım 2, 3 resimden 2. Microsoft Surface Laptop 5 (15-inch) Feet Replacement, Feet removal information: adım 2, 3 resimden 3.
    • Each foot has a recess to help pry it from the laptop:
    • The back feet recesses are closest to the back edge of the laptop.
    • The front feet recesses are closest to the front edge of the laptop.
  3. Microsoft Surface Laptop 5 (15-inch) Feet Replacement, Remove the feet: adım 3, 3 resimden 1. Microsoft Surface Laptop 5 (15-inch) Feet Replacement, Remove the feet: adım 3, 3 resimden 2. Microsoft Surface Laptop 5 (15-inch) Feet Replacement, Remove the feet: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Insert one arm of your tweezers into the recess of one of the feet.
    • Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
    • The feet eject very quickly—be careful not to lose them.
    • Remove the foot.
    • Repeat this process on the remaining feet.
  4. Microsoft Surface Laptop 5 (15-inch) Feet Replacement, Reassembly information: adım 4, 2 resimden 1. Microsoft Surface Laptop 5 (15-inch) Feet Replacement, Reassembly information: adım 4, 2 resimden 2.
    Tesa 61395 Tape
    $5.99
    • This laptop has two different types of feet. During reassembly, make sure the feet go in their correct recesses.
    • The rear feet have a single center clip.
    • The front feet have three clips and can only be reinserted one way.
    • Press the feet into their recesses to secure them to the frame.
    • If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
  5. Microsoft Surface Laptop 5 (15-inch) Feet Replacement: adım 5, 3 resimden 1. Microsoft Surface Laptop 5 (15-inch) Feet Replacement: adım 5, 3 resimden 2. Microsoft Surface Laptop 5 (15-inch) Feet Replacement: adım 5, 3 resimden 3.
    • If the feet are damaged or worn out, use 8 mm rubber furniture pads:
    • Peel a pad away from its backing.
    • Align the pad over a foot cavity and press down to secure it.
Sonuç
Spencer Day
96.042 İtibar
662 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.660 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 336
