Neye ihtiyacın var
Qualcomm X1P-64-100-103 Snapdragon X Plus deca-core applications processor
Micron MT62F1G32D2DS-023 WT:C 4 GB LPDDR5X SDRAM memory
Qualcomm PMC8380-001-00 power management
Qualcomm PMC8380VE-001 power management
Qualcomm PMC1010H-001-02 charge pump & buck regulator
Qualcomm PMC1010H-001-06 charge pump & buck regulator
Qualcomm power management
Qualcomm SMB2360-002 battery charger
Qualcomm SMB2361-002 battery charger
Likely Qualcomm clock generator
Parade Technologies PS8830 USB4, DisplayPort 2.0, and Thunderbolt 3.0 retimer
Probably camera processor
Macronix MX25U1633FZUI 2 MB serial NOR flash memory
Likely Qualcomm camera power management
Murata PE23108 LED backlight driver
Texas Instruments TPS61163A 2-ch. white LED driver
Analog Devices MAX34417 current & voltage monitor
Monolithic Power Systems MP2322 1 A synchronous step-down converter
Monolithic Power Systems DC-DC converter
NXP Semiconductors NX20P0407UK USB type-C port protector
Nexperia 74LVC2G66 dual SPST analog switch
Monolithic Power Systems MP5077GG programmable load switch
Texas Instruments TPS22964C 3 A load switch
Diodes Incorporated AP22653AFDZ-7 adjustable current-limited power distribution switch
Diodes Incorporated AP22800HB-7 programmable load switch
Richtek LDO regulator
Texas Instruments PCA9306 2-bit voltage level translator
Texas Instruments SN74LV1T08 single 2-input AND gate
Texas Instruments SN74LV1T32 single 2-input OR gate
Texas Instruments SN74AUP1G08 single 2-input AND gate
Qualcomm WCN7851-501 FastConnect 7800 WiFi 7 & Bluetooth 5.4 controller
Qualcomm 2.4 GHz front-end module
Qualcomm 5 GHz front-end module
NXP Semiconductors MIMXRT633SFFOB 32-bit ARM Cortex-M33 microcontroller w/ Xtensa HiFi4 audio DSP
Macronix MX25U51293GZ4I40 64 MB serial NOR flash memory
Qualcomm WCD9385-000 audio codec
Qualcomm audio amplifier
Renesas mixed signal array
Monolithic Power Systems MP28167GQ-A 3 A buck-boost converter
Richtek RT5753ALGQW 3 A synchronous step-down converter
Richtek RT5788AGJ8F 4 A synchronous step-down converter
Analog Devices MAX4983EEVB+ USB 2.0 DPDT analog switch
Vishay DG2723 dual SPDT analog switch
onsemi FPF2495CUCX 28 V over-voltage & over-current protection load switch
onsemi FPF1504 load management switch
Nexperia 74AVC2T245 2-bit level shifter
