Ana içeriğe geç
Microsoft Surface Pen Tip Replacement
Neye ihtiyacın var
  1. Microsoft Surface Pen Tip Replacement, Tip: adım 1, 3 resimden 1. Microsoft Surface Pen Tip Replacement, Tip: adım 1, 3 resimden 2. Microsoft Surface Pen Tip Replacement, Tip: adım 1, 3 resimden 3.
    • Order the Microsoft Surface Pen tip replacement kit.
    • Hold your pen at an angle and unscrew the top part of the pen.
  2. Microsoft Surface Pen Tip Replacement: adım 2, 3 resimden 1. Microsoft Surface Pen Tip Replacement: adım 2, 3 resimden 2. Microsoft Surface Pen Tip Replacement: adım 2, 3 resimden 3.
    • Extract the tip now that it is fully exposed.
    • When you extract the tip, make sure don't do it too hard. The inside of the pen can be broken.
  3. Microsoft Surface Pen Tip Replacement: adım 3, 3 resimden 1. Microsoft Surface Pen Tip Replacement: adım 3, 3 resimden 2. Microsoft Surface Pen Tip Replacement: adım 3, 3 resimden 3.
    • After you extract the tip, roll the tissue on toothpick.
    • I recommend cutting the tissue in half.
  4. Microsoft Surface Pen Tip Replacement: adım 4, 3 resimden 1. Microsoft Surface Pen Tip Replacement: adım 4, 3 resimden 2. Microsoft Surface Pen Tip Replacement: adım 4, 3 resimden 3.
    • Clean the inside of the top detachable part of the pen with a toothpick covered with tissue.
    • Make sure there is no residue on the edge.
  5. Microsoft Surface Pen Tip Replacement: adım 5, 3 resimden 1. Microsoft Surface Pen Tip Replacement: adım 5, 3 resimden 2. Microsoft Surface Pen Tip Replacement: adım 5, 3 resimden 3.
    • Choose the tip that you would like to use and insert in a hole.
  6. Microsoft Surface Pen Tip Replacement: adım 6, 3 resimden 1. Microsoft Surface Pen Tip Replacement: adım 6, 3 resimden 2. Microsoft Surface Pen Tip Replacement: adım 6, 3 resimden 3.
    • Screw the detachable part of the pen back on.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 60
Her zaman: 6,492
