Ana içeriğe geç
Microsoft Surface Pro 2 Camera Replacement
Neye ihtiyacın var
    1. Microsoft Surface Pro 2 Camera Replacement, LCD Display: adım 1, 2 resimden 1. Microsoft Surface Pro 2 Camera Replacement, LCD Display: adım 1, 2 resimden 2.
      • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Pro 2 Camera Replacement: adım 2, 1 resimden 1.
      • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
      • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
      • The glue is under the darker border of the device display.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Pro 2 Camera Replacement: adım 3, 1 resimden 1.
      • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
      • If the tool does not easily slide under the screen, return to heating before proceeding.
      • Slowly work the tool around the entire edge of the screen.
      FixBot'a Sor
      Yorum Ekle
    4. Microsoft Surface Pro 2 Camera Replacement: adım 4, 3 resimden 1. Microsoft Surface Pro 2 Camera Replacement: adım 4, 3 resimden 2. Microsoft Surface Pro 2 Camera Replacement: adım 4, 3 resimden 3.
      • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
      • Please note the third small connector in red.
      • Allow the glue to cool before letting it come into contact with any other surface.
      FixBot'a Sor
      Yorum Ekle
    1. Microsoft Surface Pro 2 Camera Replacement, Motherboard: adım 5, 3 resimden 1. Microsoft Surface Pro 2 Camera Replacement, Motherboard: adım 5, 3 resimden 2. Microsoft Surface Pro 2 Camera Replacement, Motherboard: adım 5, 3 resimden 3.
      • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
      • Remove the 22 screws on the bezel.
      • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
      • The three different torx screws used are T3, T4, and T5.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Pro 2 Camera Replacement: adım 6, 3 resimden 1. Microsoft Surface Pro 2 Camera Replacement: adım 6, 3 resimden 2. Microsoft Surface Pro 2 Camera Replacement: adım 6, 3 resimden 3.
      • Once the brackets are removed, set them aside.
      • The motherboard itself also has screws.
      • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
      • View the attached photo of a screw diagram to help keep track of your screws.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Pro 2 Camera Replacement: adım 7, 3 resimden 1. Microsoft Surface Pro 2 Camera Replacement: adım 7, 3 resimden 2. Microsoft Surface Pro 2 Camera Replacement: adım 7, 3 resimden 3.
      • You have now completely removed the motherboard, and it should look like the pictures shown.
      • Be sure to be cautious with all the connections with the cables on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Microsoft Surface Pro 2 Camera Replacement, Camera: adım 8, 1 resimden 1.
      • Remove the ribbon that the spudger is touching in the picture.
      • Remove the front-facing camera.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Pro 2 Camera Replacement: adım 9, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Pro 2 Camera Replacement: adım 10, 2 resimden 1. Microsoft Surface Pro 2 Camera Replacement: adım 10, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
Sonuç
abdulhameeda
108 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 6-2, Remmell Fall 2016 USF Tampa, Team 6-2, Remmell Fall 2016 üyesi
USFT-REMMELL-F16S6G2
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 32
Son 30 gün: 55
Her zaman: 1,390
