Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Microsoft Surface Pro 2 Heat Sinks Replacement
Neye ihtiyacın var
  1. Microsoft Surface Pro 2 Heat Sinks Replacement, LCD Display: adım 1, 2 resimden 1. Microsoft Surface Pro 2 Heat Sinks Replacement, LCD Display: adım 1, 2 resimden 2.
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
  2. Microsoft Surface Pro 2 Heat Sinks Replacement: adım 2, 1 resimden 1.
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
  3. Microsoft Surface Pro 2 Heat Sinks Replacement: adım 3, 1 resimden 1.
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
  4. Microsoft Surface Pro 2 Heat Sinks Replacement: adım 4, 3 resimden 1. Microsoft Surface Pro 2 Heat Sinks Replacement: adım 4, 3 resimden 2. Microsoft Surface Pro 2 Heat Sinks Replacement: adım 4, 3 resimden 3.
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
  5. Microsoft Surface Pro 2 Heat Sinks Replacement, Motherboard: adım 5, 3 resimden 1. Microsoft Surface Pro 2 Heat Sinks Replacement, Motherboard: adım 5, 3 resimden 2. Microsoft Surface Pro 2 Heat Sinks Replacement, Motherboard: adım 5, 3 resimden 3.
    • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
    • Remove the 22 screws on the bezel.
    • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
    • The three different torx screws used are T3, T4, and T5.
  6. Microsoft Surface Pro 2 Heat Sinks Replacement: adım 6, 3 resimden 1. Microsoft Surface Pro 2 Heat Sinks Replacement: adım 6, 3 resimden 2. Microsoft Surface Pro 2 Heat Sinks Replacement: adım 6, 3 resimden 3.
    • Once the brackets are removed, set them aside.
    • The motherboard itself also has screws.
    • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
    • View the attached photo of a screw diagram to help keep track of your screws.
  7. Microsoft Surface Pro 2 Heat Sinks Replacement: adım 7, 3 resimden 1. Microsoft Surface Pro 2 Heat Sinks Replacement: adım 7, 3 resimden 2. Microsoft Surface Pro 2 Heat Sinks Replacement: adım 7, 3 resimden 3.
    • You have now completely removed the motherboard, and it should look like the pictures shown.
    • Be sure to be cautious with all the connections with the cables on the motherboard.
  8. Microsoft Surface Pro 2 Heat Sinks Replacement, Heat Sinks: adım 8, 3 resimden 1. Microsoft Surface Pro 2 Heat Sinks Replacement, Heat Sinks: adım 8, 3 resimden 2. Microsoft Surface Pro 2 Heat Sinks Replacement, Heat Sinks: adım 8, 3 resimden 3.
    • Be sure to use gloves or tools because metal is sharp along the edge.
    • On the underside of the motherboard locate the heat shield which is located between the two fans near the top of the motherboard.
    • Remove the heat shield using an opening pick by lifting along the edges.
    • Remove all four Torx T5 screws located in each corner of the heat sink mounting frame.
    • Carefully lift off the heat sinks from the motherboard.
    • During reinstallation of the heat sinks, be sure to clean both contact surfaces with isopropyl alcohol and reapply thermal paste.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 811
