Ana içeriğe geç
Microsoft Surface Pro 2 LCD Display Replacement
Neye ihtiyacın var
    1. Microsoft Surface Pro 2 LCD Display Replacement, LCD Display: adım 1, 2 resimden 1. Microsoft Surface Pro 2 LCD Display Replacement, LCD Display: adım 1, 2 resimden 2.
      • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Pro 2 LCD Display Replacement: adım 2, 1 resimden 1.
      • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
      • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
      • The glue is under the darker border of the device display.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Pro 2 LCD Display Replacement: adım 3, 1 resimden 1.
      • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
      • If the tool does not easily slide under the screen, return to heating before proceeding.
      • Slowly work the tool around the entire edge of the screen.
      FixBot'a Sor
      Yorum Ekle
    4. Microsoft Surface Pro 2 LCD Display Replacement: adım 4, 3 resimden 1. Microsoft Surface Pro 2 LCD Display Replacement: adım 4, 3 resimden 2. Microsoft Surface Pro 2 LCD Display Replacement: adım 4, 3 resimden 3.
      • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
      • Please note the third small connector in red.
      • Allow the glue to cool before letting it come into contact with any other surface.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Mathew B
323 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-2, Remmell Fall 2016 USF Tampa, Team 6-2, Remmell Fall 2016 üyesi
USFT-REMMELL-F16S6G2
4 Üyeler
11 adet Kılavuz yazıldı
6Kılavuz Yorumları
After replacing the screen my surface will turn on but the screen is just black.... in device manager its showing up as a 'Digital Flat Panel'
yet the screen is still black.. faulty replacement panel???
austin jones - Yanıt Paylaş
Same thing happening to me… :(
Marco - Yanıt Paylaş
I did this procedure but i dont know why the display is not working it blink and then turnoff can somebody help me how to fix this problem
Smart Instruments - Yanıt Paylaş
I purchased a screen replacement (LCD and Digitizer), but apparently, the flex from the motherboard to the screen (the small connector in red as well as the one on the lcd) are missing. Is there a way or place I can purchase just those flex? Or do I need to get a whole new motherboard?
Roselite - Yanıt Paylaş
Myne doesn't boot. The display is dack nothing happens. It's like it's not charging. What do I do. Thanks
ARCHER TABULEY - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 63
Son 30 gün: 125
Her zaman: 16,235
