Ana içeriğe geç
Microsoft Surface Pro 2 SSD Replacement
Neye ihtiyacın var
    1. Microsoft Surface Pro 2 SSD Replacement, SSD: adım 1, 3 resimden 1. Microsoft Surface Pro 2 SSD Replacement, SSD: adım 1, 3 resimden 2. Microsoft Surface Pro 2 SSD Replacement, SSD: adım 1, 3 resimden 3.
      • Remove the two T5 Torx screws, then take off the kickstand.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Pro 2 SSD Replacement: adım 2, 3 resimden 1. Microsoft Surface Pro 2 SSD Replacement: adım 2, 3 resimden 2. Microsoft Surface Pro 2 SSD Replacement: adım 2, 3 resimden 3.
      • Use an iOpener or heat gun to melt the adhesive.
      • Insert 21 opening picks under the display.
      • Slowly lift off the display.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Pro 2 SSD Replacement: adım 3, 3 resimden 1. Microsoft Surface Pro 2 SSD Replacement: adım 3, 3 resimden 2. Microsoft Surface Pro 2 SSD Replacement: adım 3, 3 resimden 3.
      • Remove the four ribbon cables connecting to the motherboard with a spudger.
      • Remove the 52 screws securing the motherboard to the metal plates and the plastic bezel.
      • Lift off the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Microsoft Surface Pro 2 SSD Replacement: adım 4, 1 resimden 1.
      • Unscrew the two screws on the mSATA SSD and remove the SSD. (Note: This image is from a first generation Surface Pro, but it works)
      FixBot'a Sor
      Yorum Ekle
Sonuç
24 farklı kişi bu kılavuzu tamamladı.
Ronnie
3.851 İtibar
5 adet Kılavuz yazıldı
13Kılavuz Yorumları
How do you glue the back on? It looks like the adhesive that holds it on is messed up bad when it's removed.
Nate Barnes - Yanıt Paylaş
Hi Nate,
Have you figured this out? I was wondering the same thing.
Adi V - Yanıt Paylaş
You have to use double sided tape for electronics. They sell it on amazon. Use 5mm or wider to make sure the screen doesn’t fall out. Heat after application to make sure the glue sets properly.
Aaron Payer - Yanıt Paylaş
Wow, I have been contemplating one of these but after seeing that picture with the heat gun, it looks like you might as well consider it a sealed box.
Mark T - Yanıt Paylaş
Screen came off just fine using a hair dryer, but my Surface Pro 2 differs from these directions. Specifically, I got stuck not being able to remove the bezel because I don't have a T2 bit. My bezel screws are 5 x T5, 14 x T3, and 4 x T2. That doesn't match the photo shown here in step 3.
Boyd Patterson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 68
Son 30 gün: 243
Her zaman: 102,472
