Ana içeriğe geç
Microsoft Surface Pro 3 SSD Replacement
Neye ihtiyacın var
  1. Microsoft Surface Pro 3 SSD Replacement, Display: adım 1, 2 resimden 1. Microsoft Surface Pro 3 SSD Replacement, Display: adım 1, 2 resimden 2.
    • Before you begin, discharge the Surface Pro's battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally damaged during the repair.
    • The display is strongly glued to the frame of the device.
    • To remove the display, first soften the adhesive by applying heat. You can use a heat pad, heat gun, or iOpener. In a pinch, a hair dryer can also work.
    • Be careful when using a heat gun, as too much heat can permanently damage the display and/or battery.
    • Steadily and evenly heat the perimeter of the display until it's too hot to touch, and try to maintain that temperature for several minutes.
    FixBot'a Sor
    Yorum Ekle
  2. Microsoft Surface Pro 3 SSD Replacement: adım 2, 2 resimden 1. Microsoft Surface Pro 3 SSD Replacement: adım 2, 2 resimden 2.
    • Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
    • If your display is badly cracked, a suction cup may not adhere. It may help to first cover the display with a layer of packing tape. Alternatively, you can superglue your suction cup to the display.
    • Carefully insert an opening pick into the gap between the screen and the device to cut the adhesive.
    • Slide the pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
    • Work carefully—the glass is thin and will crack easily if you try to force it.
    • The wi-fi antennas are glued under the screen border along the top edge (on either side of the camera), and can be damaged easily. Use extra care when separating the top edge, and apply more heat if necessary.
    FixBot'a Sor
    Yorum Ekle
  3. Microsoft Surface Pro 3 SSD Replacement: adım 3, 3 resimden 1. Microsoft Surface Pro 3 SSD Replacement: adım 3, 3 resimden 2. Microsoft Surface Pro 3 SSD Replacement: adım 3, 3 resimden 3.
    • Continue to heat sections of the screen with the heat gun.
    • As you make your way around the screen with the heat gun, use the plastic opening tool and the opening picks to pry the screen loose.
    • The screen is extremely thin and very easy to break. Be careful working with broken glass.
    FixBot'a Sor
    Yorum Ekle
  4. Microsoft Surface Pro 3 SSD Replacement: adım 4, 2 resimden 1. Microsoft Surface Pro 3 SSD Replacement: adım 4, 2 resimden 2.
    • Lift the screen up carefully so that no wires are torn.
    FixBot'a Sor
    Yorum Ekle
  5. Microsoft Surface Pro 3 SSD Replacement: adım 5, 2 resimden 1. Microsoft Surface Pro 3 SSD Replacement: adım 5, 2 resimden 2.
    • Remove the 3 mm T3 Torx screw securing the battery connector, and disconnect the battery connector.
    • Be careful not lose the small, rectangular bridge connector that lies underneath.
    FixBot'a Sor
    Yorum Ekle
  6. Microsoft Surface Pro 3 SSD Replacement: adım 6, 3 resimden 1. Microsoft Surface Pro 3 SSD Replacement: adım 6, 3 resimden 2. Microsoft Surface Pro 3 SSD Replacement: adım 6, 3 resimden 3.
    • Remove the single 4 mm T3 Torx screw securing the display cable.
    • Lift the connector to disconnect the cable.
    FixBot'a Sor
    Yorum Ekle
  7. Microsoft Surface Pro 3 SSD Replacement: adım 7, 3 resimden 1. Microsoft Surface Pro 3 SSD Replacement: adım 7, 3 resimden 2. Microsoft Surface Pro 3 SSD Replacement: adım 7, 3 resimden 3.
    • Grasp the orange cable connected to the silver connecter.
    • Carefully lift the orange cable up until the connecter pops off.
    • The screen will now be completely disconnected.
    • The replacement display may not include all the parts needed for installation. Save all the parts from the original display, and transfer them to the new display as needed.
    FixBot'a Sor
    Yorum Ekle
  8. Microsoft Surface Pro 3 SSD Replacement, SSD: adım 8, 3 resimden 1. Microsoft Surface Pro 3 SSD Replacement, SSD: adım 8, 3 resimden 2. Microsoft Surface Pro 3 SSD Replacement, SSD: adım 8, 3 resimden 3.
    • Remove the two 4 mm T3 Torx screws securing the SSD.
    FixBot'a Sor
    Yorum Ekle
  9. Microsoft Surface Pro 3 SSD Replacement: adım 9, 2 resimden 1. Microsoft Surface Pro 3 SSD Replacement: adım 9, 2 resimden 2.
    • Lift up and pull gently on the SSD to remove it from the black connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
50 farklı kişi bu kılavuzu tamamladı.
Erik Snyder
5.460 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-18, Maness Fall 2015 Cal Poly, Team 12-18, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G18
5 Üyeler
31 adet Kılavuz yazıldı
19Kılavuz Yorumları
How do you replace the screen once the glue is melted?
bbhsascha - Yanıt Paylaş
would assume you heat and put the screen back...
Assuming you havent shattered the screen to oblivion in the process...
nyalldavis - Yanıt Paylaş
Is there a way to copy the files from the ssd card once removed?
Garry Lincoln - Yanıt Paylaş
yes, you would need an adapter to connect the msata to regular sata and connect to another computer.
Dan Wooton - Yanıt Paylaş
How's does the glass thickness compare to the Surface Pro 2? I've replaced a screen on a 2 without destroying it. Now I'm looking to replace an SSD on a 3. I'm wondering if I can expect the same type of removal.
jwelch414 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 134
Son 30 gün: 565
Her zaman: 181,115
