Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will go over how to replace the charging port on the Microsoft Surface Pro 5, also known as the Microsoft Surface Pro (2017). The iOpener is used in this guide, but a hair dryer or heat gun could also be used. See instructions for the iOpener here.
Neye ihtiyacın var
Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
Remove the ten Torx screws securing the heat sink:
Five 2.6 mm-long T3 screws
Four 3.3 mm-long T5 screws
Screw 1
Screw 2
Screw 3
Screw 4
Pry up the metal cover on the motherboard using either the nylon spudger or plastic opening tool.
5 farklı kişi bu kılavuzu tamamladı.
3 Yorum
I just ordered this one. https://www.amazon.com/gp/product/B07RT9...
I will post an update when I get it and install it.
Is there instructions how to assemble it?
