Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will go over how to remove the heat sink on the Microsoft Surface Pro 5. Removal of the heat sink will be necessary to provide ease of access for many of the components within the Surface Pro 5. It is identified by the four prominent copper bars that span the interior of the device, converging over the CPU. The iOpener is used in this guide, but a hair dryer or heat gun could also be used. See instructions for the iOpener here.
Neye ihtiyacın var
Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
Pry off the protective metal shield covering the main processor using either the nylon spudger or the plastic opening tool.
2 farklı kişi bu kılavuzu tamamladı.
