Ana içeriğe geç
Microsoft Surface Pro Battery Replacement
Neye ihtiyacın var
    1. Microsoft Surface Pro Battery Replacement, Heat edges of display: adım 1, 1 resimden 1.
      • Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
      • If you're using an iOpener it may take several cycles of reheating and applying it to soften the adhesive enough. Every time, let the iOpener sit on the display for at least a minute before reheating to allow the adhesive to soften.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: adım 2, 3 resimden 1. Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: adım 2, 3 resimden 2. Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: adım 2, 3 resimden 3.
      • Apply a suction cup as close as possible to the edge of the display.
      • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
      • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
      • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
      • The bezel is much thinner on the bottom of the display, which is the side with the Windows logo. To avoid damage, don't poke too deep with the opening pick on the bottom edge.
      • Ribbon cables and a circuit board are approx. 0.6 cm from the edge of the glass.
      • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: adım 3, 3 resimden 1. Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: adım 3, 3 resimden 2. Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: adım 3, 3 resimden 3.
      • Starting from the top edge, lift the display slightly.
      • If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
      • Before completely removing the display:
      • Disconnect the three display cables.
      • Gently peel from the frame 2 orange ribbon cables that are glued to it, as those should stay with the display. (e.g. use a thin plastic card to separate them)
      FixBot'a Sor
      Yorum Ekle
    4. Microsoft Surface Pro Battery Replacement, Removal: adım 4, 1 resimden 1.
      • Remove the display.
      FixBot'a Sor
      Yorum Ekle
    1. Microsoft Surface Pro Battery Replacement, Battery: adım 5, 2 resimden 1. Microsoft Surface Pro Battery Replacement, Battery: adım 5, 2 resimden 2.
      • Using a T3 Torx screwdriver, remove a total of 23 screws from the screen bezel of the Surface Pro.
      FixBot'a Sor
      Yorum Ekle
    2. Microsoft Surface Pro Battery Replacement: adım 6, 1 resimden 1.
      • Lift the screen bezel from the Surface Pro.
      FixBot'a Sor
      Yorum Ekle
    3. Microsoft Surface Pro Battery Replacement: adım 7, 2 resimden 1. Microsoft Surface Pro Battery Replacement: adım 7, 2 resimden 2.
      • Remove the 6 T5 screws from the panels on each side of the frame.
      • Remove 23 T2 screws from the panels.
      FixBot'a Sor
      Yorum Ekle
    4. Microsoft Surface Pro Battery Replacement: adım 8, 1 resimden 1.
      • Lift both metal panels from the frame.
      FixBot'a Sor
      Yorum Ekle
    5. Microsoft Surface Pro Battery Replacement: adım 9, 2 resimden 1. Microsoft Surface Pro Battery Replacement: adım 9, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using tweezers, gently pull the eight orange ribbon cables from their sockets.
      FixBot'a Sor
      Yorum Ekle
    6. Microsoft Surface Pro Battery Replacement: adım 10, 2 resimden 1. Microsoft Surface Pro Battery Replacement: adım 10, 2 resimden 2.
      • Unscrew the 17 T5 torx screws on the mother board with the T5 torx screw driver
      FixBot'a Sor
      Yorum Ekle
    7. Microsoft Surface Pro Battery Replacement: adım 11, 1 resimden 1.
      • Once all screws are removed, gently lift up the logic board with your hands to pull it out.
      FixBot'a Sor
      Yorum Ekle
    8. Microsoft Surface Pro Battery Replacement: adım 12, 2 resimden 1. Microsoft Surface Pro Battery Replacement: adım 12, 2 resimden 2.
      • Use your hands to pry off the entire battery pack with enough force to overcome the glue keeping the batteries in place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
40 farklı kişi bu kılavuzu tamamladı.
Jonathan Choi
1.090 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-20, Regan Fall 2013 Cal Poly, Team 8-20, Regan Fall 2013 üyesi
CPSU-REGAN-F13S8G20
4 Üyeler
17 adet Kılavuz yazıldı
24Kılavuz Yorumları
Thank you for that awesome guide!
Do you know where can i buy a battery for surface pro 2??
Thanks
John john - Yanıt Paylaş
I am also trying to find out where to acquire the Surface Pro batteries...???
Tristan Irons - Yanıt Paylaş
im also looking for a surface pro replacement battery.
Lekan Adesanya - Yanıt Paylaş
I just bought one for $70 at a site called newpower99.com... should be here in 2 days. I have no idea if it will work, but it says it comes with a toolkit to replace it. I hope it works.
Matt - Yanıt Paylaş
Did you have success installing the Newegg battery?
asmac - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 188
Son 30 gün: 871
Her zaman: 270,760
