Giriş
Use this guide to replace the charging port in a Microsoft Surface Pro.
Neye ihtiyacın var
Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
5 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Where do you get a replacement charging port at?
