Ana içeriğe geç
Giriş
This replacement guide will help you with the following:
Completely remove the old kick-stand and install a new one.
  1. Turn the tablet so the back is facing up.
    • Turn the tablet so the back is facing up.
    • Lift the kickstand to access the screws.
    • Remove the two T5 Torx screws located on the left and right sides.
  2. Android Tamir Setleri
    Yeni bir ekran veya pil, bir tamir kiti kadar yakınında.
    Hemen Alışveriş Yapın
  3. To remove the kickstand, gently pull up until the three tabs slide out of the slots on the back of the device.
    • To remove the kickstand, gently pull up until the three tabs slide out of the slots on the back of the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Mark
350 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 8-20, Regan Fall 2013 Cal Poly, Team 8-20, Regan Fall 2013 üyesi
CPSU-REGAN-F13S8G20
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
I had trouble getting the center tab to slide out of the slot. After looking at the other tabs, which came out easily, I noticed that the tabs are not composed of a single piece but are actually two sheets glued together (like two pieces of tape). Somehow the two pieces of tape composing the center tab had come apart, exposing their adhesive surfaces, and sticking to an inner surface. I managed to push them apart enough from the outside with a flathead screwdriver so that I could slide the center tab out. However, the other piece is stuck inside the device.
artlives13 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 2
Past 7 Days: 52
Past 30 Days: 266
Her zaman: 26,369
