Giriş
This replacement guide will help you with the following:
Completely remove the old kick-stand and install a new one.
Neye ihtiyacın var
Turn the tablet so the back is facing up.
Lift the kickstand to access the screws.
Remove the two T5 Torx screws:
One from the left hinge
One from the right hinge
To remove the kickstand, gently pull up until the three tabs slide out of the slots on the back of the device.
9 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I had trouble getting the center tab to slide out of the slot. After looking at the other tabs, which came out easily, I noticed that the tabs are not composed of a single piece but are actually two sheets glued together (like two pieces of tape). Somehow the two pieces of tape composing the center tab had come apart, exposing their adhesive surfaces, and sticking to an inner surface. I managed to push them apart enough from the outside with a flathead screwdriver so that I could slide the center tab out. However, the other piece is stuck inside the device.
