Ana içeriğe geç
Microsoft Surface Pro X SSD and SIM Card Door Removal
Neye ihtiyacın var
  1. Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the kickstand: adım 1, 2 resimden 1. Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the kickstand: adım 1, 2 resimden 2.
    • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
    • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
    • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
  2. Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the SSD and SIM card door: adım 2, 2 resimden 1. Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the SSD and SIM card door: adım 2, 2 resimden 2.
    • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
    • Press firmly to open the door.
  3. Microsoft Surface Pro X SSD and SIM Card Door Removal, Remove the SSD and SIM card door: adım 3, 1 resimden 1.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adam O'Camb
197.087 İtibar
416 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 30
Son 30 gün: 139
Her zaman: 9,487
