Ana içeriğe geç
Microsoft Zune 80 Case Replacement
Neye ihtiyacın var
  1. Microsoft Zune 80 Case Replacement, Case: adım 1, 1 resimden 1.
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  2. Microsoft Zune 80 Case Replacement: adım 2, 1 resimden 1.
    • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
    • Be careful with removing these screws! These screwheads are prone to breaking.
  3. Microsoft Zune 80 Case Replacement, Remove the Casing: adım 3, 2 resimden 1. Microsoft Zune 80 Case Replacement, Remove the Casing: adım 3, 2 resimden 2.
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
turey
400 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-5, Maness Fall 2009 Cal Poly, Team 6-5, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G5
5 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
I have followed these steps but im unable to get the back case off, any tips for a stubborn backing?
zippy9765 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 4,708
