Ana içeriğe geç
Microsoft Zune 80 Hard Drive Replacement
Neye ihtiyacın var
  1. Microsoft Zune 80 Hard Drive Replacement, Case: adım 1, 1 resimden 1.
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Microsoft Zune 80 Hard Drive Replacement: adım 2, 1 resimden 1.
    • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
    • Be careful with removing these screws! These screwheads are prone to breaking.
    FixBot'a Sor
    Yorum Ekle
  3. Microsoft Zune 80 Hard Drive Replacement, Remove the Casing: adım 3, 2 resimden 1. Microsoft Zune 80 Hard Drive Replacement, Remove the Casing: adım 3, 2 resimden 2.
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
    FixBot'a Sor
    Yorum Ekle
  4. Microsoft Zune 80 Hard Drive Replacement, Remove the Silver Tape: adım 4, 2 resimden 1. Microsoft Zune 80 Hard Drive Replacement, Remove the Silver Tape: adım 4, 2 resimden 2.
    • Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Microsoft Zune 80 Hard Drive Replacement: adım 5, 3 resimden 1. Microsoft Zune 80 Hard Drive Replacement: adım 5, 3 resimden 2. Microsoft Zune 80 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound, it is now disengaged from the hard drive.
    • If the cable doesn't come off easily, the black bar has not been un-clicked.
    • The hard drive cable (ZIF cable) is very fragile. Try to keep it in its original shape and bend it as little as possible.
    • Now gently pull the orange hard drive cable to remove it from the hard drive.
    • Lift the hard drive from the device.
    • Hard Drive Replacement Only: Check to make sure the hard drive cable is in good condition and then connect the new hard drive in the same place, following the steps in reverse order.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
turey
417 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-5, Maness Fall 2009 Cal Poly, Team 6-5, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G5
5 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
what model hard drive did you utilize during its replacement?
thanksss
RAFI V DEMIRJIAN - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 31
Son 30 gün: 102
Her zaman: 14,273
