Giriş
This guide can be used to remove and replace the LCD screen of the Zune 80GB.
Neye ihtiyacın var
Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery.
Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound, it is now disengaged from the hard drive.
Now gently pull the orange hard drive cable to remove it from the hard drive.
Lift the hard drive from the device.
Hard Drive Replacement Only: Check to make sure the hard drive cable is in good condition and then connect the new hard drive in the same place, following the steps in reverse order.
Remove two more pieces of silver tape from the bottom of the device. One of these pieces is below the other.
Remove the battery from the device with the cables still connected.
Carefully lift up the mother board located at the base of the Zune. Unclip the orange ribbon cable in the same manner as in the previous steps.
Remove the mother board from the Zune, leaving the black wire connected.
Carefully remove the wireless assembly that runs along the top and upper left edges of the Zune.
Remove the assembly and the battery together as a unit.
Bir başkası bu kılavuzu tamamladı.
