Ana içeriğe geç
Microsoft Zune HD Controls Sidebar Replacement
Neye ihtiyacın var
  1. Microsoft Zune HD Controls Sidebar Replacement, Upper Rear Panel: adım 1, 1 resimden 1.
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Microsoft Zune HD Controls Sidebar Replacement: adım 2, 2 resimden 1. Microsoft Zune HD Controls Sidebar Replacement: adım 2, 2 resimden 2.
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Microsoft Zune HD Controls Sidebar Replacement, Controls Sidebar: adım 3, 2 resimden 1. Microsoft Zune HD Controls Sidebar Replacement, Controls Sidebar: adım 3, 2 resimden 2.
    • Use a Zune opening tool to gently lift the media button lever off the post cast into the inner chassis.
    • Try not excessively rotate the media button lever about this post.
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Can the side panels (hello from Seattle) come off as well?
Evoke - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 3,150
