Giriş
Replace your Zune HD's lower rear panel.
Neye ihtiyacın var
Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
Bir başkası bu kılavuzu tamamladı.
