Ana içeriğe geç
Microtek ScanMaker 5900 New Locking Mechanism Replacement
Neye ihtiyacın var
    1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: adım 1, 3 resimden 1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: adım 1, 3 resimden 2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: adım 1, 3 resimden 3.
      • Loosen the screws on the serial port by turning them counter clockwise by hand.
      • After loosening the screws, pull the serial port out.
      FixBot'a Sor
      Yorum Ekle
    2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: adım 2, 3 resimden 1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: adım 2, 3 resimden 2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: adım 2, 3 resimden 3.
      • Lift lid to its vertical position.
      • Pull lid straight up to remove it from the scanner.
      FixBot'a Sor
      Yorum Ekle
    1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: adım 3, 3 resimden 1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: adım 3, 3 resimden 2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: adım 3, 3 resimden 3.
      • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
      FixBot'a Sor
      Yorum Ekle
    2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: adım 4, 3 resimden 1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: adım 4, 3 resimden 2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: adım 4, 3 resimden 3.
      • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
      • Go all the way along the chassis until you can lift the upper lid.
      FixBot'a Sor
      Yorum Ekle
    3. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: adım 5, 3 resimden 1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: adım 5, 3 resimden 2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: adım 5, 3 resimden 3.
      • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
      • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
      • Grab the ribbon cable and gently pull it out of its slot with your fingers.
      • The upper lid can now safely be removed from the bottom lid.
      FixBot'a Sor
      Yorum Ekle
    1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: adım 6, 3 resimden 1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: adım 6, 3 resimden 2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: adım 6, 3 resimden 3.
      • Locate the locking mechanism in the front left hand corner of the device.
      • Gently push on it until it becomes loose.
      • Rotate and jiggle it until it comes out the bottom of the scanner.
      • Find a replacement locking mechanism and insert it into the scanner.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Nesheim
59 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G9
2 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 36
Her zaman: 1,749
