Ana içeriğe geç
Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement
Neye ihtiyacın var
  1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: adım 1, 3 resimden 1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: adım 1, 3 resimden 2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: adım 1, 3 resimden 3.
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: adım 2, 3 resimden 1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: adım 2, 3 resimden 2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: adım 2, 3 resimden 3.
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: adım 3, 3 resimden 1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: adım 3, 3 resimden 2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: adım 3, 3 resimden 3.
    • Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering.
    • Use tweezers to push these tabs in.
    • Gently pull the plastic covering off of the upper lid.
  4. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: adım 4, 3 resimden 1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: adım 4, 3 resimden 2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: adım 4, 3 resimden 3.
    • Grab the plastic wire housing near the serial port.
    • Gently pull and jiggle the wire housing until it comes free from the circuit board.
  5. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: adım 5, 2 resimden 1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: adım 5, 2 resimden 2.
    • Gently lift up the bulbs and remove the wires from the plastic.
    • After completely freeing the bulbs, buy new ones and replace.
Sonuç
Taylor Nesheim
59 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G9
2 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 1,161
